Where to find ACC / Ignition and Dash Illumination wires?
Discussion in 'Audio & Video' started by goffredo, Jun 1, 2019.
  1. Jun 1, 2019 at 10:37 AM
    goffredo
    goffredo [OP] Grease Nipple
    Lake Tahoe, California
    2018 Tundra Limited Double Cab Magnetic Gray
    Hey guys,
    I'm installing an air compressor push-button switch on the driver's side dash area of my 2018 Limited Tundra.
    It requires tapping into a wire that is hot when the key is in the ACC position, i.e. an ignition switch, and a wire whose voltage varies with dash illumination to control the switch's illumination.
    I was poking around with my little test light but with the sensitive modern electronics I'm afraid I'm going to fry something. So I thought I'd ask.
    Does anyone know where I can tap into the ACC / Dash Illumination wires? Preferable somewhere on / close to the driver's side kickpanel area, rather than behind the radio cluster. Thank you!
  2. May 19, 2020 at 11:29 AM
    MazingarZ4x4
    MazingarZ4x4 New Member
    WA
    2024 1794 Edition
    Do u have a picture please?
  3. May 19, 2020 at 11:31 AM
    BamaMan44
    BamaMan44 Roll Tide Roll! Bama Fan till I die! & Go 'Hawks!
    Andre
    Tucson
    Trailbreaker - 2017 Black CrewMax SR5 4x4
    I used a wire on one of the non used panels in that area. There was a plug that wasn't being used and used a circuit tester to find the correct wire and spliced into it.
  4. May 19, 2020 at 1:14 PM
    Ketchumj
    Ketchumj New Member
    South Texas
    2020 Tundra SR5 4x4 Double Cab
    2020 Tundra 4x4 SR5 Magnetic Grey – TSS Off Road Toytec Complete performance 3” Lift kit with Aluma Series 2.5 Coilovers, SDP Upper Control Arms, Black Rhino 18” Gauntlet Wheels - +12 Offset, Nitto Terra Grapplers – 295/70R18, Victory 4x4 strike Front Bumper, Fab Fours Premium Rear Bumper, Smittybilt X20 12k Winch
    Light blue wire on my 2020 for illumination
