Where the F do I pry to get the tail light off?
Discussion in '2.5 Gen Tundras (2014-2021)' started by ToyotaTundraMike, Jan 12, 2018.
  1. Jan 12, 2018 at 2:16 PM
    ToyotaTundraMike
    ToyotaTundraMike [OP] Not A New Member
    2015 Tundra
    Jesus christ it would have been to difficult for just the 2 torx screws to hold the tail light assembly in, I had to make a second trip to auto parts store for some pry tools. Only problem is I am just mucking up the painters tape all around my tail light and not popping it loose. Where is the sweet spot??
  2. Jan 12, 2018 at 2:18 PM
    TundraTss
    TundraTss The Mistress
    Brandon
    2019 TRD SR5
    Everything. Literally.
    When I popped my lights out so I could VHT then I had the same problem. I just ended up putting about 5 layers of tape down, as well as taping the edge of the light and just pried as gently as I could in a spot that damage, should it occur, would be the least visible, until the seal popped. Didn’t end up cracking or scratching anything, so I called it a win.
    I can’t say that there’s a sweet spot. It’s all about finesse.
    God speed.
  3. Jan 12, 2018 at 2:19 PM
    ToyotaTundraMike
    2015 Tundra
    Welp nvm I just had to grow some nuts and pull harder
    15whtrd, 4x4_Angel, dandailey and 3 others like this.
  4. Jan 12, 2018 at 2:20 PM
    TundraTss
    Brandon
    2019 TRD SR5
    Problem solved.
    ToyotaTundraMike[OP] likes this.
  5. Jan 12, 2018 at 2:20 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    Tools to pry? I just used my hands....takes some strength but not enough to break it
    15whtrd, Munk, rons23 and 1 other person like this.
  6. Jan 12, 2018 at 2:28 PM
    Plastic spudger set works wonders..................[​IMG]
    trayday and 4x4_Angel like this.
  7. Jan 12, 2018 at 2:50 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    That's all you needed
  8. Jan 12, 2018 at 2:55 PM
    jfrd30
    jfrd30 Lead, Follow, or Get the Hell Out of My Way
    2013 TRD Tundra
    WHOA, WHOA, WHOA there buddy!!! We don't need to be breaking shit here! Slow down and take a deep breath. You are smarter than that damn tail light....just use some stremf and strategery! YOU CAN DO IT!
    15whtrd, Filthy13, Black Wolf and 2 others like this.
  9. Jan 12, 2018 at 2:58 PM
    ToyotaTundraMike
    2015 Tundra
    Lol! Thanks for the motivation but I have now conquered the demon that is a Tundra tail light. Think the frustrating part was trying to use the pry tools and be extra careful instead of just tugging on it.
  10. Jan 12, 2018 at 3:00 PM
    jfrd30
    2013 TRD Tundra
    You sir are the master of all that you survey....great job!
  11. Jan 12, 2018 at 3:04 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    um, you shouldn't have had to pry it all. once the torx screws are out, it should have basically fallen off the truck.
  12. Jan 12, 2018 at 3:09 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Tape? Pry tools? WTF? Just grab the fucker and yank it off!!! :muscleflexing:
    Munk, Filthy13 and 4x4_Angel like this.
  13. Jan 12, 2018 at 3:48 PM
    ToyotaTundraMike
    2015 Tundra
    There is a clip at the top and bottom that also holds it in. Similar to the clips that are around the grill. If it was just the torx screws it would have been cake. Gotta push or pull at the right angle and at the right spot to release the clips but it almost feels like your going to break it before it will finally release. Maybe mine was just a little tight since it was her first time.
  14. Jan 12, 2018 at 3:54 PM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    weird. mine just popped right out but then, i did take her dinner and whisper sweet nothings...
  15. Jan 12, 2018 at 4:14 PM
    Mine fell off so quick I almost dropped it....Go figure .....
  16. Jan 12, 2018 at 4:15 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Ron you are the Man! :benchpress::bowdown: Must be something with the 3rd gen, mine popped right out on my 08.
    Black Wolf and NewImprovedRon like this.
  17. Jan 12, 2018 at 5:17 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    Next time I need help....I'M CALLING YOU. :D:anonymous:
    4x4_Angel[QUOTED] and Black Wolf like this.
