WHERE SHOULD MY TRANS FLUID DIP STICK LEVEL READ
Discussion in '1st Gen Tundras (2000-2006)' started by derryt98, Dec 18, 2022.
  1. Dec 18, 2022 at 7:45 PM
    derryt98
    derryt98 [OP] New Member
    Derry
    2002 Tundra SR5
    Title basically. Lost some from when I changed the radiator. trying to get it to where it needs to be. This was when I checked it hot. Ran for over an hour. Just wondering where it should be on the dipstick when hot. Is there a better way to do this? Also, i checked it cold and it was around the same level, which doesn’t really make sense. please help!!!
  2. Dec 18, 2022 at 8:06 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Two of the marks should have HOT engraved on stick for identification.
    You want the level between the marks for HOT after driving the truck and checking the fluid.
    This is the only info I found in FSM:
    des2mtn likes this.
  3. Dec 19, 2022 at 12:44 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    You should be checking it cold right after you start the engine not when the engine is off. I typically drive mine 10-20 minutes on 30-40 mph backroads to get it up to temp. The shifting through the gears never really worked for me.
    Cold is between the two indentations that’s lower on the stick. Hot is between the two higher indentations on the stick.
    FirstGenVol likes this.
