Where does everyone take the tundra for an alignment?
Discussion in '2.5 Gen Tundras (2014-2021)' started by WhistlingPete72, Apr 26, 2023.
  1. Apr 26, 2023 at 12:41 PM
    WhistlingPete72
    WhistlingPete72 [OP] New Member
    2017 Toyota Tundra SR5 CREWMAX
    where does everyone take the tundra for an alignment? a large chain or a mom and pop?
  2. Apr 26, 2023 at 1:25 PM
    It's more of the alignment techs experience....not so much the shop. The dealers alignment prices are about the same as the other shops. You always have that option.
  3. Apr 26, 2023 at 2:06 PM
    Demented Canine
    Demented Canine Hiding in the Baffles
    Extreme Southeast Georgia
    2020 MGM SR5 DC
    The Toyota Dealer where I purchased it. ;)
    1lowlife, WhistlingPete72[OP] and 1UP like this.
  4. Apr 26, 2023 at 2:08 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Southern Tire Mart. They align RVs and big rigs so I know they can deal with oversized rubber
  5. Apr 26, 2023 at 2:28 PM
    FO LO
    FO LO New Member
    17 CM w/ 5.7 and 4.30s
    Firestone lifetime as many as you want fur $189 with their $20 off coupon
  6. Apr 26, 2023 at 2:33 PM
    Jjclamdips
    Jjclamdips New Member
    Wichita, Ks
    2000 Access Cab
    Tires Plus, lifetime alignment, our local stores do a great job.
    WhistlingPete72[OP] likes this.
  7. Apr 26, 2023 at 2:36 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Depends on your set up; if you have lift, larger tires, or anything else that may change suspension geometry, I'd take it to a 4WD / off-road shop that has an experienced tech w/good equipment. It might cost you $50 more, but worth it... (tires are too damn expensive)
    If it's stock then anyone w/decent equipment and an experienced tech can give you a good alignment, and like others have mentioned some of the chains do lifetime for a little extra if you trust their tech :thumbsup:
    NewImprovedRon, rock01, ATV25 and 5 others like this.
  8. Apr 26, 2023 at 2:51 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    This.
  9. Apr 26, 2023 at 3:13 PM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
  10. Apr 26, 2023 at 6:39 PM
    AverageJoe
    AverageJoe New Member
    DFW TX
    21 DC SR 4WD
    Same as FO LO, Firestone lifetime
  11. Apr 26, 2023 at 6:50 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    In front of my garage. Trackace for toe + FasTrax for camber. I'll get a SharkEye Falcon for proper 4WD alignment soon.
    The reason for DIY alignment is:
    - all shops around only do front tie rods (meh...)
    - Volvo dealer's tech said front camber is fixed and he won't be doing anything. He was too young to know my platform that actually has ~1 degree of camber adjustment. I showed him which bolts he needs to turns, he went into denial.
    - the best local shop does it all, but they let the car sit for a few hours. The car is equipped with self-leveling suspension, a few hours is enough for it to squat. The guy then aligns it, but in a few hundred feet the car raises and the alignment is fubar
    So I decided to do alignments myself, and it works marvelous with simple tools.
  12. Apr 26, 2023 at 7:19 PM
    WaterTrash
    WaterTrash New Member
    Same here. Fort Worth
  13. Apr 26, 2023 at 7:32 PM
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    Me too... but I made it even simpler. You have to get the truck level regardless, or at least the front and rear on the same plane. I used a 4' level gauge, and pieces of plywood. Then for camber I used a digital magnetic angle gauge. For caster it's best to have a little more on the passenger side, and it's fine to have as much as possible, so that one is easy. For toe I eyeballed it with the rear tires.
  14. Apr 26, 2023 at 7:55 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Make a video and show us what you do to make it work.
  15. Apr 26, 2023 at 8:00 PM
    rruff
    rruff New Member
    That sounds like too much work...o_O :rofl:
  16. Apr 26, 2023 at 8:03 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I think the same thing about doing my own alignments :p
  17. Apr 26, 2023 at 9:24 PM
    rruff
    rruff New Member
    I learned a long time ago that it's usually less time and trouble to do things myself vs futzing around taking it to a shop. And that doesn't even include $$$. Plus I know exactly who to blame if something is wrong!
  18. Apr 27, 2023 at 2:59 AM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    I take mine to an independent local commercial truck shop.
  19. Apr 27, 2023 at 3:03 AM
    BuzzardsGottaEat
    BuzzardsGottaEat New Member
    '16 Tundra DCLB
    Round Tires
    The Tires Plus here put my tires and then recommended an alignment. They said the truck was too big for their machine…
  20. Apr 27, 2023 at 3:43 AM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    ANYONE but the DEALER !
  21. Apr 27, 2023 at 4:10 AM
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    I've had great "luck" with Les Schwab, but their guy at our local store is great. Just like others have said an experienced tech is probably the biggest factor.
  22. Apr 27, 2023 at 5:14 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    4WD alignment is much simpler with solid rear axle. Pretty much it's not going anywhere, unless damaged. On my car with multilink independent rear suspension I adjust the thrust vector by trial, which works, but takes too much time.
    What kills me my alignment with tools worth of under $200 works better than $200 shop alignment on a $35k alignment rig... People are not proud for the quality of their work anymore.
    WhistlingPete72[OP] and ATV25 like this.
  23. Apr 27, 2023 at 5:26 AM
    ATV25
    Terry
    Redding, CA
    2019 Platinum
    Well said vtl ! No pride in workmanship / craftsmanship is a HUGE problem !
  24. Apr 27, 2023 at 11:09 AM
    AverageJoe
    DFW TX
    21 DC SR 4WD
    Looks like need to do some research to figure out how to do this myself....any existing videos that helped anyone with their journey to figuring this out would be appreciated.
  25. Apr 27, 2023 at 11:40 AM
    rruff
    rruff New Member
    You should definitely search for info. Here is one: https://www.tundras.com/threads/how-to-do-an-alignment-at-home.136/
    I used a similar angle gauge, but stuck it to the brake rotor which I think is better.
    I didn't worry about caster except to make it as high as possible with my stock UCAs; it isn't critical for tire wear like camber and toe. From the factory the cams on both sides were nearly identical, so I just kept that relationship (made left and right the same). I have a lift though, so set the front pivots all the way in, then adjusted the rear ones until camber was zeroed. This maximizes caster.
    Toe isn't hard to eyeball. This is the last step after you've set camber and caster and tightened the cams. You use the tie rods to adjust. Sight along the side of the front tires to the rear ones. If they line up on both sides, or have a tiny toe in, you are good. This step took a lot of iteration since the steering wheel would move a little.
    The cam bolts have very high torque, so you need a good long wrench and strong arms.
    vtl and AverageJoe like this.
  26. Apr 27, 2023 at 12:10 PM
    rruff
    rruff New Member
    One thing that is important to remember is that once you have a good alignment, it should stay good... unless you bend metal parts, or wear bushings. If the bushings wear enough to throw off your alignment it might be time to replace them. In other words unless you have an event where high stress is evident, you shouldn't be needing alignments on a regular basis.
    If you have a flat place to park, both camber and toe can be eyeballed pretty well. If that looks good, then whatever issues you might be experiencing are probably not alignment related.
    Adjusting the tie rods (toe) is a lot easier than messing with the LCA cams. Toe is also the most critical for tire wear.
  27. Apr 27, 2023 at 12:17 PM
    djhase
    djhase member
    David
    Southern Illinois
    2019 Silver Tundra TRD
    Used to take it to the dealer. Never thought they did a good job. Now my brother in law has his own shop and does them for me. Just had had new Michelin's put on with an alignment. Got 65K out of the stock Michelins so I got another set.
  28. Apr 27, 2023 at 12:20 PM
    AverageJoe
    DFW TX
    21 DC SR 4WD
    Appreciate the feedback.
    Our situation is we live in a rural area about a mile down a gravel county road that is, to be generous, moderately maintained. Couple that with lots of deep pot holes on our county roads and we need regular alignments or maybe the techs just suck and I'm not properly analyzing the need.
    Plus I want to learn it anyway which is just an added bonus.
  29. Apr 27, 2023 at 12:52 PM
    rruff
    rruff New Member
    If you are DIY oriented I think it's a good one to learn. Pretty simple and inexpensive.
