Where are the stake hole pockets ?
Discussion in 'General Tundra Discussion' started by augerhandle, Dec 5, 2020.
  1. Dec 5, 2020 at 9:41 AM
    augerhandle
    augerhandle [OP] New Member
    2021 Silver Tundra SR5
    Just bought a 2021 SR5 - appears to have 4 stake pockets, but covered over with plastic on top of body rail. Do I have to cut outs in the plastic or does it pop off it pried?
  2. Dec 5, 2020 at 9:46 AM
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    cut it out.
  3. Dec 5, 2020 at 9:56 AM
    BIGUGLY
    Paul
    2018 Limited
    Yep cut along the lines
  4. Dec 5, 2020 at 10:37 AM
    augerhandle
    Thanks, but there are no lines to indicate where to cut - any suggestions on how to accurately locate where to cut ?
  5. Dec 5, 2020 at 11:30 AM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    Pop the rail covers off, mark and cut. I did it a few weeks ago. It's not that hard.
    Stand outside the bed, just aft of the cab and squeeze the rail cover, gently work your fingers under the inner side and roll towards you, then work down the rail. The last "plug" closest to the tailgate was a bit snug, but I got both sides off and back on again with no breakage.
    NewImprovedRon likes this.
  6. Dec 5, 2020 at 1:46 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
  7. Mar 4, 2024 at 7:15 AM
    diz
    diz New Member
    2020 CrewMax TRD 4x4
    For those just looking for a quick and dirty roughly right location to drill a starter hole, on my 2020 CM the center of the stake pocket holes line up with the inside tie down rail end clip edges. Like this:
    I'm going to use this to finish the hole for my adarac rails, because it's an excuse to play with my router.
    https://www.amazon.com/gp/product/B00NWZAQB8
    DrRansom likes this.
  8. Mar 4, 2024 at 7:32 AM
    borla123
    borla123 The Pits
    Ontario
    18 Tundra TRD OR - '17 4Runner Torsen Full Time 4wd
    Driver Grip Handle Borla Dual, Line X, ESP Underseat
    wow 4 year bump.
    after you drill a hole just use a heavier duty exacto knife for a clean cut.
