When you can’t find that pesky oil leak.....
Discussion in '1st Gen Tundras (2000-2006)' started by AV8R4AA, Apr 13, 2021.
  1. Apr 13, 2021 at 10:41 PM
    AV8R4AA
    AV8R4AA [OP] New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    I was surprised to find this out. I had an oil leak around the oil filter housing.
    I could not pin point it. Thought it might be the oil pan, maybe the oil filter.
    Perhaps the oil pressure sender.
    NOPE to all that. It turned out the the the “figure 8” O ring. PN 15692. I bought it at the Toyota
    Dealer. I asked him how many he has ever sold. He said I was the only person to
    Order that part. Any way, after months of chasing oil spots, it was that O-ring.
    DRAIN OIL BEFORE STARTING THIS !!!!!!
  2. Apr 13, 2021 at 11:56 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    Oil filter housing gasket I have done many 100s on GM trucks very common leak but never done one on a tundra
  3. Apr 14, 2021 at 2:10 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Hmmm...I've been getting 1-2 drops from time to time on the garage floor under the oil filter, I'll have to check this out!
    NewImprovedRon likes this.
  4. Apr 14, 2021 at 8:10 AM
    AV8R4AA
    Greg
    Justin Texas
    2005 Tundra XSP
    According to the parts salesperson at Toyota, not a common part.
    It’s buried enough to not see the actual leakage. I really didn’t know if
    mine was leaking there. The oil would travel along the oil pan rail.
    I thought it was something else till I pulled the parts catalog.
    That is where I found the “double barrel shotgun” O’ring. Sure enough,
    That cured the leak.
    MS22 likes this.
  5. Apr 14, 2021 at 8:16 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    How difficult was it to replace? I can't even picture where that is from the diagram.
  6. Apr 14, 2021 at 10:25 AM
    AV8R4AA
    Greg
    Justin Texas
    2005 Tundra XSP
    It wasn’t hard to replace. It’s the flange that mounts to the engine block.
    Gotta move some stuff out of the way.
  7. Apr 14, 2021 at 10:50 AM
    Gotta be lower front driver's side of the engine in front of the motor mount where the oil filter is mounted.
  8. Apr 14, 2021 at 10:55 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    If you get it at the Lexus stealership it will be cheaper than the Toyota stealership... it was 1.61 at Lexus, and 5.80 at Toyota parts counter.. if you get it online in Toyota is. 69 cents... same figure 8 gasket part number.. I got mine at Lexus, then I forgot to remove it from my Toyota cart and bought it again with other parts cuz I'm a dummy...
    Darkness likes this.
  9. Apr 14, 2021 at 1:12 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Is your truck a v6? I tried that part number for the V8 and didn't get anything. Here's the V8 diagram
  10. Apr 14, 2021 at 3:56 PM
    AV8R4AA
    Greg
    Justin Texas
    2005 Tundra XSP
    I have the V8
    Your picture is not of the V8, mine is.
    Perhaps my supplied part number is incorrect.
  11. Apr 14, 2021 at 4:47 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
  12. Apr 14, 2021 at 5:59 PM
    AV8R4AA
    Greg
    Justin Texas
    2005 Tundra XSP
    I intended to show where my Tundra oil leak was coming from.
    I didn’t cross reference the part number.
    I failed on that.
  13. Apr 15, 2021 at 10:23 AM
    rock climber
    This was great info! I have a leak around that area and I never thought there might be on o-ring inside.
  14. Jul 3, 2021 at 4:48 AM
    BubbaW[QUOTED] likes this.
  15. Jul 3, 2021 at 4:57 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Our 2008 sequioa (2nd gen) has the 4.7L
  16. Jul 3, 2021 at 4:59 AM
    I was not aware they put the 4.7L in the 2nd gen Sequoia. Thought they all got the 5.7L. Muy interesante
    Tundra2[QUOTED] likes this.
  17. Jul 3, 2021 at 5:06 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Clearly needs some PHM, but this rig is not mine. I just get to drive it at times.
    The only 4wd automobile in the family. I'm not sure what year they changed to the 4.6
    N84434 likes this.
  18. Jul 3, 2021 at 5:41 AM
    Maybe the intake cover is just a typo and that's really a 5.7
    bmf4069 and Tundra2[QUOTED] like this.
  19. Jul 3, 2021 at 5:57 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    You would be correct !
  20. Jul 3, 2021 at 5:59 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Trust me, it ain't. I kinda wish though :muscleflexing:
  21. Jul 4, 2021 at 7:32 AM
    Bummer man.
  22. Jul 12, 2021 at 12:50 AM
    shootemintheface
    shootemintheface New Member
    01' Tundra V8 Limited New Frame
    How likely is the "engine oil cooler" to leak oil into the coolant? I've been trying to flushing my coolant and currently on distilled water. But there's a yellow tint to the water. I've checked for head gasket leak with the indicator fluid and it checks fine.
  23. Jul 12, 2021 at 12:54 AM
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    The ‘cooler’ circuit in the radiator? Its possible.
    The external cooler? Unlikely.
  24. Jul 12, 2021 at 1:13 AM
    shootemintheface
    I should had been more clear, engine oil cooler. Not the transmission cooler. Currently I have the transmission preheater loop bypassed. And currently trying to flush out the coolant in the engine. I have a new radiator installed.
  25. Jul 12, 2021 at 2:22 AM
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    My bad, i wasnt paying attention, and daydreaming about aluminum radiators. Almost forgot about the filter cooler. And i have no idea, gonna try to find pics of the innards.
  26. Mar 7, 2022 at 8:46 AM
    Diablo675
    Diablo675 New Member
    2001 Tundra
    Tuff Country lift, headers, new Jeep seats, custom made console, many more.
    I tried to replace this on my 2001 4.7 Tundra, but the ac compressor is blocking the top bolt. Did you have this problem and, if so, did you have to move the ac compressor to access that bolt? I finally had to put it back together and it leaks more now. Here's a picture of what I am dealing with. Thanks for any help and yes, I know that this is an older thread, but is the only one that I could find.
  27. Mar 7, 2022 at 9:52 AM
    AV8R4AA
    Greg
    Justin Texas
    2005 Tundra XSP
    Loosen the compressor. DO NOT CRACK THE HOSES OPEN.
    push the compressor over to gain access.
    Diablo675 likes this.
  28. Mar 7, 2022 at 10:54 AM
    Diablo675
    2001 Tundra
    Thank you SO much for your help! That's what I thought. Do you remember if you had to loosen or remove the serpentine belt also? I imagine that you would have to. I'll look to see how many more bolts there are than the one showing. I couldn't find ANY information on this repair other than Sequoias that didn't have this problem with the ac compressor. You rock!
  29. Mar 7, 2022 at 12:00 PM
    AV8R4AA
    Greg
    Justin Texas
    2005 Tundra XSP
    I 5hink there are 3bolts holding that flange on.
    You have 2 out already. When you get in there, see if
    your “double barrel o ring is hard and useless..
    take off your serpentine belt. Much easier to access.
  30. Mar 7, 2022 at 12:37 PM
    Diablo675
    2001 Tundra
    Thanks again! Yes, the ac comp is in the way, so I'll have to get the belt off and see what other bolts are securing the ac compressor. By loosening the lower ac compressor bolt, I was able to gently rotate the oil filter bracket around that top bolt but I didn't want to remove the ac compressor as the truck was half way out of the garage door at my shop and the door couldn't go down. Also, the 67 Corvette was sitting outside. Couldn't leave it out overnight or the door up. Thanks so much for taking the time to answer this thread as you are the only one that I know of that has done this.
