When to use 4wd
Discussion in 'General Tundra Discussion' started by joonbug, Nov 16, 2015.
  1. Nov 16, 2015 at 10:37 AM
    joonbug
    joonbug [OP] °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Okay I just got back from Tahoe and it snowed. My previous grand Cherokee was a full time 4wd so I never had to worry about switching. When I got to the mountain, chains were required. It was snowing and there was a lot of snow roadside, but the road itself was pretty much just melted water and maybe just a little bit of slush. Should I be in 4wd or do I need more snow under the tires?
    GNTundra, Viper3G and dcsleeper408 like this.
  2. Nov 16, 2015 at 11:06 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    I havent used my tundra in the snow yet. but stock tires should be good enough.. maybe not on ice. but dont quote me on that.
    But you will be good in 2by til you you start getting squirley. then just flip it to 4by and you will be good. keep it safe speed and turn smooth with easy braking.
  3. Nov 16, 2015 at 12:26 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Sounds to me like you were kind of in that grey area where you could've probably safely been in either.
    With high grip tires, 2WD would've probably been fine most of the time. With the typical "stock" tires, 4WD would've been fine as well, at slower speeds. More than say, 50-60mph might be a little too much, it kind of depends. The wet roadway would've offered enough slippage to prevent the driveline from binding until you got into some intown driving where you're making sharper turns. This is just my perspective, not witnessing firsthand the conditions you were driving in and no firsthand experience of your driving comfort level and skill. Also, safer is better. FWIW
  4. Nov 16, 2015 at 12:36 PM
    When you begin to lose traction from the start, use 4HI.
    Please take note, 4HI only helps with traction, not stopping.
    Many are under the belief that using 4HI is almost like invisible mode. That is far from the truth.
    stefan702 and dcsleeper408 like this.
  5. Nov 16, 2015 at 5:51 PM
    Agreed. For example, ice can totally mess up the ECM. Will be confused as to what wheel to apply brakes. My Tacoma had the same problem. Sometimes your pedal will go to the floor while the ECM is still trying to figure out what to do. I turn off nanny's when driving in town at lower speeds to avoid that issue when icy. As far as driving speeds in 4 HI, I drove the last 700 to 800 miles, in less than ideal winter conditions thru Yukon Territory and on to Anchorage at speeds up to 70 mph with zero, nil, none, affects. No binding at all. Ever. Remember the roads were not dry which would have fracked up something for sure. As long as the surface you are driving on is wet, snowy, icy, you are good to go. I've been there and done that. Actual experience, not speculation as to what "could" happen. Would and probably will do it again. All depends on experience of course. Don't go beyond your abilities/comfort level. Play it safe until you get to know your what your truck can and can not do. :thumbsup:
    vidman, Viper3G and dcsleeper408 like this.
  6. Nov 16, 2015 at 9:09 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    I wondered how fast you could go in 4HI. Up to 70 huh? For some reason i was thinking you could not go over 60.
  7. Nov 16, 2015 at 9:10 PM
    As fast as u want, technically. You can't engage it past 55 IIRC.
    Black Wolf likes this.
  8. Nov 19, 2016 at 1:42 PM
    stefan702
    stefan702 IG: 702stefan_
    Randy
    Las Vegas
    2015 Tundra TRD Offroad
    IG: 702stefan_
    haha invisible mode!!! ROOOOAARRR can't stop me now!
    T-Rex266[QUOTED] likes this.
  9. Nov 19, 2016 at 1:56 PM
    Viper3G
    Viper3G Why isn't work more like this?
    Rick
    2016 Crew Max 1794 4WD Super White
    Phillips X-treme Ultinon LED H4 bulbs, 3M Color Stable 35 tint on front doors, 3M Crystalline 40 on sunroof, OEM bed liner, OEM running boards, Morimoto fog LEDs, Fold-A-Cover G4 Elite, Husky X-Act Contour floor mats
    Thanks @joonbug and to all the contributors. I used to have a 4WD and always wondered about this. My 07 Tundra is only 2WD but I'm looking to get a 4WD next time.
    joonbug[OP] likes this.
  10. Nov 19, 2016 at 2:04 PM
    vidman
    vidman New Member
    Rick
    Massachusetts
    When pulling the space shuttle up a steep hill...
  11. Nov 19, 2016 at 3:07 PM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Depends is it running forwards or backwards at you?
    T-Rex266 and GNTundra like this.
  12. Nov 19, 2016 at 3:16 PM
    vidman
    vidman New Member
    Rick
    Massachusetts
    Good lord man..who would take a pic of something like that
  13. Nov 19, 2016 at 3:41 PM
    thumper7799
    thumper7799 Bad Girls Drive Bad Toys!
    Erika
    2007 Nautical blue Tundra SR5 duel exhaust
  14. Nov 19, 2016 at 3:44 PM
    thumper7799
    Erika
    ROTFLMFAO. Noooo, me no likey!
    gosolo, NewImprovedRon and GNTundra like this.
  15. Nov 19, 2016 at 3:51 PM
    thumper7799
    Erika
    @GNTundra and your poor fuckin sister! Get her some help, those hemorrhoids look painful!
    vidman, gosolo and GNTundra like this.
  16. Nov 19, 2016 at 4:04 PM
    thumper7799
    Erika
    oh ok...I will pass that on to your sister. Sounds like you know that from experience :devil:
  17. Nov 19, 2016 at 5:45 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    This thread went sideways fast.
    T-Rex266, thumper7799 and GNTundra like this.
  18. Nov 19, 2016 at 6:04 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Better question is "who would wear sweatpants in that situation?"
  19. Nov 19, 2016 at 6:05 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Figured you'd have been on here long enough to realize this is par for the course! LOL
  20. Nov 19, 2016 at 6:10 PM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Where did this thread even come from? It was one year ago.
    GNTundra likes this.
  21. Nov 19, 2016 at 6:18 PM
    Tundra Fan
    Toby
    LOL, in that case, it took a year to go sideways. :D
  22. Nov 19, 2016 at 6:46 PM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Lol
    Law323 likes this.
  23. Nov 19, 2016 at 7:44 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
  24. Nov 19, 2016 at 7:45 PM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
  25. Nov 19, 2016 at 7:47 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    GNTundra and joonbug[OP] like this.
  26. Nov 20, 2016 at 10:21 AM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Lmfao. Still not working. Closer though
    Law323 likes this.
  27. Nov 20, 2016 at 10:27 AM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
