Wheezing
Discussion in 'General Tundra Discussion' started by TundraDude4x4, Mar 8, 2019.
  1. Mar 8, 2019 at 12:50 PM
    TundraDude4x4
    TundraDude4x4 [OP] New Member
    2010 Pyrite Mica V8 4x4 DC
    My Tundra is a 2010 and has around 74,000 miles on it and it had developed a wheeze in the last two years and I can’t figure it out. Every time I crank it and drive it, it makes a weird wheeze and every time I slow down you can hear the wheeze shift down while the gears do. It’s been bothering me a lot lately and I was wondering if y’all could help me figure out what it is.
  2. Mar 8, 2019 at 12:51 PM
    Sound clip????
  3. Mar 8, 2019 at 1:11 PM
    TundraDude4x4
    I’m kinda new to the forum, How do I add a sound clip?
  4. Mar 8, 2019 at 1:12 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    gotta upload to youtube
    BTBAKER and Black Wolf like this.
  5. Mar 8, 2019 at 1:17 PM
    TundraDude4x4
    Okay thanks
    joonbug[QUOTED] likes this.
  6. Mar 8, 2019 at 1:21 PM
    YsoSeRiouS!
    YsoSeRiouS! A good day...for a good day
    NorCaL
    2019 White Platinum CM
    Ganmercy and Trooper2 like this.
  7. Mar 8, 2019 at 1:28 PM
    TundraDude4x4
  8. Mar 8, 2019 at 1:32 PM
    YsoSeRiouS!
    NorCaL
    Wheel bearings maybe...I’m only guessing wheel bearings because i has a sound like that on my 4runner
  9. Mar 8, 2019 at 1:37 PM
    TundraDude4x4
    So on your 4 Runner did replacing the wheel bearings fix the noise?
  10. Mar 8, 2019 at 1:38 PM
    YsoSeRiouS!
    NorCaL
  11. Mar 8, 2019 at 1:40 PM
    YsoSeRiouS!
    NorCaL
    Have it lifted and play with each wheel and see if there’s any play on any of them, it’s just a guess but does it get louder as you go higher in mph?
  12. Mar 8, 2019 at 1:48 PM
    15whtrd
    15whtrd Mr. Blonde
    I can’t really hear it in your video. What does it completely change pitch as it downshifts or is it just changing pitch as you slow down? Does it do it in neutral as you slow? Have you been greasing your prop shaft?
  13. Mar 8, 2019 at 1:50 PM
    Padj
    Padj Life is what happens when you're making plans
    Denver, Colorado
    2019 Limited CM TRD MGM
    Did it start when you changed anything to do with your audio system?
    YsoSeRiouS! likes this.
  14. Mar 8, 2019 at 1:51 PM
    TundraDude4x4
    Yeah
  15. Mar 8, 2019 at 1:52 PM
    TundraDude4x4
    It changes pitch as I down shift
  16. Mar 8, 2019 at 1:53 PM
    TundraDude4x4
    It did but it never sounded like it was coming from speakers though
  17. Mar 8, 2019 at 1:56 PM
    15whtrd
    15whtrd Mr. Blonde
    I remember we had an old Toyota RV that did that through the speakers. It would home and change as we shifted gears. I was a little kid at the time.
  18. Mar 8, 2019 at 1:57 PM
    15whtrd
    15whtrd Mr. Blonde
    Maybe for the heck of it pull the radio fuse and amp
    1UPPER and YsoSeRiouS! like this.
  19. Mar 8, 2019 at 2:01 PM
    TundraDude4x4
    I’m about to go do that, I mean is there anyway to fix it? Without taking the sound system out.
  20. Mar 8, 2019 at 2:02 PM
    15whtrd
    15whtrd Mr. Blonde
    You may have to check your ground on anything you installed. That is if pulling a fuse helps.
  21. Mar 8, 2019 at 2:14 PM
    TundraDude4x4
    I actually had it done by a audio shop near my house
    15whtrd[QUOTED] likes this.
  22. Mar 8, 2019 at 2:23 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    I was also curious if it was a back feed from the stereo. Usually the higher the RPMs the louder it gets.
    15whtrd and YsoSeRiouS! like this.
  23. Mar 8, 2019 at 2:48 PM
    TundraDude4x4
    Is there anyway to fix it?
  24. Mar 8, 2019 at 2:51 PM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    Check the ground for your amps
    TundraDude4x4[OP] and 1UPPER like this.
  25. Mar 8, 2019 at 2:55 PM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    Sounds like a whistling to me. There’s that little metal cage just after the MAF sensor that can crud up, especially if you’re running an oil-able air filter. Just wanted to throw in my $.02 that’s it doesn’t sound like speaker/amp issues, I’ve had those...
  26. Mar 8, 2019 at 3:04 PM
    1UPPER
    TEXAS
    Flux capacitor!
    I would first pull the fuse for the stereo and amps and try and trouble shoot if it’s the stereo first as mentioned above.
  27. Mar 8, 2019 at 3:09 PM
    TundraDude4x4
    I’m gonna try that probably tonight and if no luck with that I’m probably gonna take it back to the audio shop and have them check the ground wiring.
