Wheels & Tires
Discussion in 'Wheels & Tires' started by Duds11, Jul 30, 2018.
  1. Jul 30, 2018 at 12:51 PM
    Duds11
    Duds11 [OP] New Member
    2016 Bright White Tundra TRD Pro
    K&N Cold Air Intake Sway bars Camper Shell
    Needing new tires...present set-up is still stock. Will 295/70R18 fit on my OEM TRD Pro 18" rims? I know I may have to lift it some, no problem, but my concern is the rim/tire compatibility. Any help greatly appreciated... Thanx...
    jewsNbrews likes this.
  2. Jul 30, 2018 at 12:53 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Look up tires you want and size...should give rim size needed. Usually listed as 8-10 width etc
    belanger9 likes this.
  3. Jul 30, 2018 at 1:01 PM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    To build on this showing an example - check the tires sizes and specifications. Usually one of the closest columns to the tire size with be the approved rim width. Someone can correct me as I only know the stock TRD wheels and not the Pro wheels, but I believe they are the same size and are 8 inches in width.
  4. Jul 30, 2018 at 1:05 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Pro and TRD are the same wheel. One just has the milled accents a d the other is all black.
    belanger9[QUOTED] likes this.
  5. Jul 30, 2018 at 1:07 PM
    chphilo
    chphilo Tundra addict
    Western PA
    There are some members who mounted 295/70/18 on a Pro without lifting it. Remember that a Pro sits about 2 inches higher in the front than other trim Tundras.
  6. Jul 30, 2018 at 2:06 PM
    Duds11
    Thanx Folks...sounds like the stock 8" width should suffice...I'm not a rock crawler-level off-roader and am looking at the Michelin LTX M/S which are the newer version of the factory installs on the TRD Pro...just keepin' it where the TRD engineers planned for it to go! Have fun and be safe out there Folks...
