Wheels rubbing caliper
Discussion in 'Wheels & Tires' started by Dustydirt19, Apr 19, 2017.
  1. Apr 19, 2017 at 5:13 PM
    Dustydirt19
    Dustydirt19 [OP] Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    I know a lot of you guys have or have had tacoma's before. This is a question I am trying to help my dad out with. He has a '17 tacoma sr5 and he got aftermarket rims (16") and they are rubbing on the front calipers. Any advice on how to remedy this? Is this common on tacos? The place is sending back his rims to get different ones (17's) just didn't want the same thing to happen to him again.
    I might as well ask this...any problems with tundras rubbing brake calipers too or is it more of a taco thing
  2. Apr 19, 2017 at 5:41 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
  3. Apr 19, 2017 at 5:52 PM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    This has to be a f*****g joke right?
  4. Apr 19, 2017 at 5:57 PM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    It depends on the wheels. Most aftermarket steelies and some procomp 16s don't have enough clearance on the spoke section of the wheel and require spacers to clear the caliper. He's better off trading them in and buying wheels that fit properly.
    Tundras will have the same problems with most (not all) 17" wheels on the market.
    Why? If you don't like his question you can just move on to the next thread.
  5. Apr 19, 2017 at 6:00 PM
    Dustydirt19
    Dustin
    Duluth, MN
    Thanks I appreciate it!!
    GNTundra and Bob like this.
  6. Apr 19, 2017 at 6:04 PM
    jberry813
    Lake Tahoe
    Shit. @Bob is here.
  7. Apr 19, 2017 at 6:58 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    I ran into the same thing on my dad's '10 Tacoma. Replaced his steel 17's with Mikey Thompson classic II's in 17" and even with a lesser offset (don't recall the exact offset) they still rubbed the caliper. I did 1" Spider Trax spacers to remedy the problem. If I had to do it over again I would have ordered 18" rims and a 65 sidewall.
    Dustydirt19[OP] likes this.
  8. Apr 19, 2017 at 7:48 PM
    jberry813
    Lake Tahoe
    Steelies and Mickeys generally speaking were designed for chevys. Despite the same lug pattern, the width of the calipers is larger on the Tacoma. The majority 16" wheels work on tacomas just fine. My personal preference is to buy Toyota specific hub centric wheels like @SCSPerformance so you don't have to deal with shitty lug centric balancing.
