wheels and tires
Discussion in 'Wheels & Tires' started by Dario, Nov 27, 2021.
  1. Nov 27, 2021 at 10:59 AM
    Dario
    Dario [OP] New Member
    2018 Toyota tundra limited
    level kit 2.5 front
    I'm thinking on getting 295/70 17 tire on 17 method wheels 0 offset on a 2018 tundra
    , I have a leveling kit on it, any info on this set up, I'm concern about offset for what I been reading
  2. Nov 27, 2021 at 11:18 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Well, first post needs a hearty welcome.. Official welcome.
    Check out the Garage section under wheels/tires and past threads on that subject matter. Good luck
    D4x4TRD and HighDesertSurfer like this.
  3. Nov 27, 2021 at 11:25 AM
    Dario
    level kit 2.5 front
    Thank you for welcome me into this forum, I been reading this forum a lot, great info, i have learn a bet about tundras
  4. Nov 28, 2021 at 9:38 PM
    pvmike
    pvmike Home Depot flexing
    Los Angeles
    2014 Platinum Super White
    TRD Pro suspension, supercharger, 5.29 gears, Auburn LSD
  5. Dec 5, 2021 at 8:08 AM
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    I have 295/70/17s and Bilstein 6112s - front is 1.75" rear is stock height (leveled). I did the wheel well liner "mod" and that was it. I rub the flaps in hard reverse but its just plastic and has cleared itself over time- you could remove flaps but you may get a few small rock chips due to the poke from the 0 offset. The type/make of tire will factor in as well. Im on Mickey Thompson ATZs.
    where-do-i-trim-this.11691
