Wheel trim piece - Scratched/scuffed
Discussion in 'Detailing' started by dano9258, Apr 29, 2024.
  1. Apr 29, 2024 at 8:22 AM
    dano9258
    dano9258 [OP] New Member
    2024 Limited 4x4 OR Pkg
    MX4 Cover
    I went to pick up groceries this morning and when i got out of the truck, saw the rear driver side plastic trim piece around the wheel well had a scratch from the front, and then a scuff/scratch on the rear portion. It looks almost like someone walked by the truck and wasn't paying attention with something they were carrying and scratched the front and then it didnt hit anything by the wheel, before striking the rear trim piece causing the scuff and scratch worse on the back. There is no damage at all to the metal of the truck around the trim and i cant feel it with my fingernail either. I tried going over with just water but that didn't work. Any ideas how to get it to fade or disappear? I have ScratchX at home that I haven't tried but I don't know if that will work. Otherwise, i saw that piece is just bolted on the outside of the wheel well, how much for a new one? This sort of thing really upsets me as I almost always find end spots and park way out to avoid this sort of thing. Why can't others be careful and not damage other peoples vehicles!? Thanks ahead of time.
  2. Apr 29, 2024 at 11:01 AM
    RCwyoming
    RCwyoming New Member
    RC
    2019 Tundra 4X4 CM MGM
    I have better things to upset me.
  3. Apr 29, 2024 at 7:34 PM
    PERRY1060
    PERRY1060 Hammer Down
    Perry
    Indiana
    Blk on Blk 22 Ltd 4x4
    TRD wheels, skid plate, black fender flares, mud flaps and running boards. Pirelli Scorpion 275/70/20 Allterrain Plus tires
    Do you have pictures?
  4. Apr 30, 2024 at 10:36 AM
    briarpatch
    briarpatch New Member
    Pics would be helpful....but, in lieu of that.....do not use the Scatch-X...that will not improve your situation. Once these hard plastic pieces get scuffed, the best you can do is to try and minimize the appearance of the damage with a trim dressing...but understand that it's not a permanent solution. There are trim coating products, like Cerakote, which will last longer and protect the trim as well
    ToyoMafia likes this.
  5. Apr 30, 2024 at 12:16 PM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    Unfortunately all newer toyota plastics scratch easy. If it really drives you mad just order new ones. I’ve gone this approach a few times.
  6. May 7, 2024 at 11:00 AM
    War Machine
    War Machine SSEM # 5 3MW
    I wonder if Meguair’s PlastX would help at all. It’s more for clear plastics and headlight restoration, but maybe it would mitigate the scratches a bit? It’s cheap to try, especially if you’re considering buying a whole new trim piece. I’ve tried it on some plastic before. While it didn’t eliminate the issue, it did reduce it a bit.
