Wheel torque specs?
Discussion in 'Wheels & Tires' started by boardude, Jun 14, 2015.
  1. Jun 14, 2015 at 11:20 AM
    boardude
    boardude [OP] I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Anyone know the torque specs for the TRD aluminum wheels? The owners manual says 154 ft/lb but I think thats for the steel spare tire. I think the aluminum wheels are 97 ft/lb but really cant find anything in any of the forums.
  2. Jun 14, 2015 at 12:11 PM
    chphilo
    chphilo Tundra addict
    Western PA
    That's correct. 97 ft-lb for Aluminum wheels and 154 for steelies.
  3. Jun 14, 2015 at 12:28 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Thank you sir!
  4. Jun 14, 2015 at 4:26 PM
    Rkcruza
    Rkcruza New Member
    Bob
    2002 Tundra AC 4WD TRD OR SR5
    De Badged / Decaled, Firestone Ride Rite Air Bags w/ Daystar Cups, 17" Rims, Big Brake kit w/ slotted & drilled rotors, plus lots of work related stuff.
    I've got 95# written down in the shop so the 97# should be it as they give a range of about 5# or so.
  5. Sep 15, 2022 at 7:06 AM
    hessler
    hessler New Member
    2017 Tundra SR5 TRD Offroad
    So far: LineX bed liner Future: Retrax bed cover, Helwig Rear Sway Bar
    I initially thought the torque was 154# ofor my Tundra and used that for years to set my torque wrench. A guy at the dealership set me straight. Meh, since the techs use air wrenches to tighten the lug nuts I don't think I did much harm compared to what they would have. I tried to loosen a lug nut on my wife's Highlander they had tightened and I couldn't do it by jumping up and down on a 2' breaker bar. I took it back and had them redo it with my torque wrench set to her specs. At least we can change a tire on the side of the Interstate while 16 wheelers zip by.
  6. Sep 15, 2022 at 7:11 AM
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
    97lbs is correct. I set my wrench to 100 and call it close enough. When I swapped over to my PRO wheels, I had a hard time taking loosening the lugs the dealer installed when they installed my new steering rack. Ended up using a Milwaukee Impact gun to get them loose.
  7. Jul 12, 2025 at 11:17 AM
    The_BiG_HawK
    The_BiG_HawK New Member
    2010 toyota tundra rwd 4.6l double cab
    Switching from stock steel wheels to 20inch fuel darkstar cast aluminum wheels. Should I still stay at 97ft lbs for lug nut torque?
  8. Jul 12, 2025 at 12:21 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Unless your Fuel wheels use the washered Toyota alloy lug nuts like this
    then the 97ft lb spec will be too low. Washered lug nuts have far less friction then tapered seat lug nuts to get the same amount of elastic stretch on the studs.
    I’m not saying that you should go as high as 154ft-lbs on aftermarket alloys with tapered seat nuts either, just pointing out that Toyota’s specs are for their products and why there’s a difference when the wheel studs themselves are the same.
  9. Jul 12, 2025 at 4:37 PM
    The_BiG_HawK
    So what are ya saying then? I did 97 before I saw this but didn't drive it yet
  10. Jul 12, 2025 at 5:15 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    you'll be fine on 97 for the time being; theres a BIG offroad shop where I live and they torque to factory spec on aftermarket wheels
    I would suggest you check your torque every couple months or so; it also wouldn't hurt to call Fuel on monday and see if they can offer you a torque spec
    The_BiG_HawK[QUOTED] likes this.
  11. Jul 12, 2025 at 5:27 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    I’ve been torquing my fuel wheels with the proper acorn style lugs to 98 lbs for 6 years and over 100k miles. Zero issues.
    The_BiG_HawK likes this.
  12. Jul 12, 2025 at 8:25 PM
    The_BiG_HawK
    Sounds like sound advice lol I appreciate your help. Thanks again
    joseph_womack[QUOTED] likes this.
