Wheel swap from steel to machined question.
Discussion in 'Wheels & Tires' started by eagleguy, Mar 23, 2021.
  1. Mar 23, 2021 at 8:42 AM
    eagleguy
    eagleguy [OP] New Member
    The 2021 Tundra SR5 I recently purchased came with the standard 18" OEM style steel wheels. I purchased used but as new "TOYOTA TUNDRA TRD 18" MACHINED FACTORY OEM WHEELS". Will I be able to use the same lug nuts the steel wheels came with or do I need to get different lug nuts. I have been told the factory steel wheel lug nuts are the same by some when pricing the swap at tires places and others say I will need new lugs. Seller indicated same lugs used and is only providing wheels and center caps.
    Thanks!
  2. Mar 23, 2021 at 8:46 AM
    polox40
    polox40 New Member
    2016 DC Limited
    LineX Toyota black running boards
    I have a 2016 tundra with steel wheels for winter tires, they came with their own set of lug nuts. Same for 2019 highlander.
  3. Mar 23, 2021 at 8:49 AM
    eagleguy
    Question is will the steel wheel lug nuts work on the machined aluminum wheels.
  4. Mar 23, 2021 at 8:54 AM
    Pineapplehead
    Pineapplehead New Member
    Philip
    New Meadows, Idaho
    2010 Super White Tundra DC
    Usually steel wheels use a conical seat lug nut, while aluminum use a flat face washer. Spin one off of yours and take a look. Or, call your local Toyota parts counter and have them look it up.
  5. Mar 24, 2021 at 11:02 PM
    paulbk
    paulbk New Member
    The steel lugs will not work. You will need the “mag-style” lug nuts to work on the alloys.
    The tpms sensors in the steel rims generally will not work in the alloy rims also.
    Hbjeff, TechWrench and Tundra2 like this.
  6. Mar 28, 2021 at 11:14 AM
    TechWrench
    TechWrench New Member
    Gary
    Hawley, PA
    '08 Tundra White, DC SR5 5.7, TRD Off Road Pkg
    Toyota Bedliner, Under Cover Bed cover, Oem back-up camera system.
    What he said.
    Hbjeff likes this.
