Wheel spacers
Discussion in 'Wheels & Tires' started by Weldcar, Jan 2, 2016.
  1. Jan 2, 2016 at 11:17 AM
    Weldcar
    Weldcar [OP] New Member
    2013 rock warrior
    I have a stock 2012/13 rock warrior with the factory 17 in rims. I'm putting a leveling kit on and was thinking of running 2in wheel spacers on it for a wider footprint and larger tires. Any thoughts on this? I know some say you loose clamping force and I've seen bad things on one tons happen while loaded down. But on a half ton? I don't haul a bunch of weight and my camper is only 3000 lbs...thanks!
  2. Jan 2, 2016 at 1:31 PM
    Why 2"? Just use the 1.25." Should be enough.
    Relentless likes this.
  3. Jan 2, 2016 at 1:54 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I have 1.25" wheel spacers on mine. Spidertrax. No issues. Go with a name brand like spidertrax or bora and install them correctly to the procedure and you will be fine. Where you go wrong is with a cheap wheel spacer or incorrect installation.
    Weldcar[OP] likes this.
  4. Jan 2, 2016 at 2:14 PM
    Weldcar
    2013 rock warrior
    Cool thanks guys!
  5. Jan 2, 2016 at 2:15 PM
    csuviper
    Broomfield, CO
    Keep in mind tire places will not install the wheel spacers for you and some won't even install your wheels on. Discount tire changed there policy and now will install wheels and service your tires but still won't touch the spacers.
  6. Jan 2, 2016 at 2:17 PM
    csuviper
    Broomfield, CO
    I have 1.25" sorry. Changed above.
  7. Jan 2, 2016 at 2:17 PM
    csuviper
    Broomfield, CO
  8. Jan 2, 2016 at 2:20 PM
    csuviper
    Broomfield, CO
    Check the marketplace. There might be a set or two for sale.
  9. Jan 2, 2016 at 4:15 PM
    Weldcar
    2013 rock warrior
    Ya I wasn't sure on the size of adapters. And yes I only would use name brands. I was just wondering if any issues have been noticed with them. I wouldnt think on half tons it would be a problem. I just want to run the stock
    Yes I've run into that issue also...
  10. Jan 2, 2016 at 7:37 PM
    lbcdan
    lbcdan Zip it up and zip it out
    Daniel
    Long Beach, CA
    2018 Toyota Tundra CrewMax 4x4
    Toytec Boss Coilovers, Total Chaos UCA, Icon 57720P Shocks, Toytec Shackles, TRD Off-Road Wheels, SpiderTrax Spacers, BakFlip MX4, Clazzio Seat Covers, Rough Country Light Bar, BajaDesigns Foglights
    Keep us updated with some pics. I am looking to do the same thing. I will probably keep my stock tires but I will be adding Spidertrax (ran them on my Tacoma and FJ) and Bilstein 5100s to level the front (also ran on my FJ and Tacoma).
  11. Jan 15, 2016 at 4:33 AM
    PolarbearTRD
    PolarbearTRD New Member
    Newton Nh
    2015 white crewmax TRD
    Carbon fiber wrap trim interior. Carbon fiber pillars, yitamotor 6000k led headlights. Rigid industries 50" led light bar,
    Been thinking of doing same thing on my 15 CM any update?
