Wheel size options for 1794
Discussion in 'Wheels & Tires' started by Smitty4Bama, Apr 15, 2019.
  1. Apr 15, 2019 at 9:05 AM
    Smitty4Bama
    Smitty4Bama [OP] New Member
    2014 Tundra 1794
    Hi ALL! New to the board... Sorry if a repeated question, but looking for info on downsizing wheels on my 1794 to 18" to have beefier tire look. Anyone know if this is possible? If this is a mistake, please time in and give your opinions.
    Thanks!
  2. Apr 15, 2019 at 9:09 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Welcome!
    Yes, a lot of guys change from 20" to 18", some even to 17" without problems. Bigger sidewall will give a softer ride (through bumps and potholes, but maybe lose a little stability around corners - although almost negligible)
    You can generally upsize to 33" tires without modifications, and 34" with minor 3/1 leveling.
  3. Apr 15, 2019 at 9:09 AM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    You can go as small as 17" for wheel size. Your tire size will depend o. The offset of your new wheels and if you lift or not. Welcome aboard!
  4. Apr 15, 2019 at 9:10 AM
    Boerseun
    Ferdie
    Sarasota Florida
  5. Apr 15, 2019 at 9:14 AM
    Smitty4Bama
    2014 Tundra 1794
    Good info! Thanks...
  6. Apr 15, 2019 at 9:14 AM
    Smitty4Bama
    2014 Tundra 1794
    Thanks!
    Berdine[QUOTED] likes this.
  7. Apr 15, 2019 at 9:16 AM
    Smitty4Bama
    2014 Tundra 1794
    I've got a leveling kit on it now. My worry was having an issue with brakes/calipers fitting in the 18" rim. Man, if I can run a set of 18" Fuel Vapors and 34" tires, I'll be ecstatic!
    Berdine and Boerseun[QUOTED] like this.
  8. Apr 15, 2019 at 9:16 AM
    matrdguy
    matrdguy New Member
    Pete
    'The Notch' Western MA
    MGM 2016 Tundra Platinum 1794 Edition
    18" TRD Wheels, Falken Wildpeak AT3 275 75 18, Westin Bed Rug with Linex, Window Vents, TRD Sway Bar, Bilstein 6112/5100 CB +3 shackels, CB Shims, Chrome Tailgate Letters. More To Come....
    I have 18's on my 1794.... I think they look much better than the 20's and I don't feel the bumps as much as the 20's
    Plus I didn't like the looks of the SimChrome 1794 wheels it came with..
  9. Apr 15, 2019 at 9:19 AM
    Smitty4Bama
    2014 Tundra 1794
    Thanks! This just helps to feel good about the change!
  10. Apr 15, 2019 at 9:26 AM
    matrdguy
    matrdguy New Member
    Pete
    Before
    After
    Jaybird79 likes this.
  11. Apr 15, 2019 at 9:43 AM
    Smitty4Bama
    2014 Tundra 1794
  12. Apr 15, 2019 at 9:52 AM
    matrdguy
    matrdguy New Member
    Pete
    also has #/2 Lift 6112 and CB Shackles in back
  13. Apr 15, 2019 at 10:19 AM
    Berdine
    Binghamton, NY
    295 70 18s would be good
  14. Sep 14, 2021 at 3:44 AM
    vandman
    vandman New Member
    Van
    2021 Toyota Tundra 1794 Metallic Gray
    I have the same Truck what are the specs for your newTRD wheels and falken tires? any modificatiions? i would like to get rid of the ugly chrome 20
