Wheel Protection Help?
Discussion in 'Wheels & Tires' started by Ronin73, Dec 1, 2018.
  1. Dec 1, 2018 at 5:57 AM
    Ronin73
    Ronin73 [OP] New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    Hello!
    I don't really get in to the wheel changes and stuff...I just don't care. I specifically chose my new 2019 Tundra because it had the base steel wheels pictured below.
    However, I have noticed on the Internet that after awhile these wheels see rust and chips, etc. Do you have any advice on how to protect them? A sealant? Wax? Anything? Or do I just keep them clean as much as possible?
    Any help you can offer will be greatly appreciated. Thanks!
    Ronin
  2. Dec 1, 2018 at 6:08 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    Wax would be a good idea for the front of the wheel. Coat the back with an anti corrosive, CRC SP-400.
    Question for others. Is plasti dip clear really clear or is it foggy? This could be a good application for that.
    Ronin73[OP] likes this.
  3. Dec 1, 2018 at 8:54 AM
    KirthGersen
    KirthGersen New Member
    So Calif
    2018 SR5 Crewmax
    I would just keep them clean. If they start to degrade, steel wheel "takeoffs" are pretty cheap to buy on ebay or craigslist (in fact, I've got a set of 700mile, steel wheels & tires for sale!)
    Water & crud accumulates in the "valley" between the wheel's "face" and the main rim, and can't easily drain out -- the area where the valve stem is located. That might be an area to watch for indications of premature corrosion. When I had the steelies on truck, i'd blast that area with the water hose ... then it will slowly dry out after a few dozen miles of higher speed driving.
  4. Dec 1, 2018 at 9:15 AM
    polox40
    polox40 New Member
    2016 DC Limited
    LineX Toyota black running boards
    I just got toyota 18" steel wheels for winter and mounted duratrac's on them, i got them clear coated at a bodyshop; the owner owed me a favor. 3 coats both sides.
    They only cost 400$ in Canada cant be much in the states you can just replace them after a while.
    Ronin73[OP] and texasrho83 like this.
  5. Dec 1, 2018 at 9:18 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    ^^^ this. Clear coat would be my route. Welcome to the MGM crew!
  6. Dec 1, 2018 at 9:58 AM
    Ronin73
    Thanks, everyone!
