wheel offset question
Discussion in '3rd Gen Tundras (2022+)' started by ytank1, Sep 8, 2023.
  1. Sep 8, 2023 at 8:25 AM
    ytank1
    ytank1 [OP] New Member
    MD
    To those who's more knowledgeable in the matter
    I am looking into TIS wheels 554BM in 20X10 -19 offset
    I will wrap those in 35X12.5X20s
    How much poke will I have on the 3rd gen Tundra
    I am looking to stick with 1 inch or less of poke
    If anyone has a similar set up a pic would be greatly appreciated
    Thanks in advance
  2. Sep 8, 2023 at 8:33 AM
    This thread has some at a +12 offset.
    https://www.tundras.com/threads/12-offset-wheel-on-2023-tundra.121085/
    A -19 offset would push the wheel out another 31mm, or 1.22 inches. That's just the wheel. With the proposed 12.5" wide tires on the 10" wide wheels you'll poke even further.
    Also, you are aware that as you poke out more, even just the inch you're after (giggity), you can start running into rub issues that require removing mud flaps and possibly chopping parts of the frame, right?
    ytank1[QUOTED][OP] likes this.
  3. Sep 8, 2023 at 9:11 AM
    ytank1
    MD
    That's what I was afraid of but I wasn't sure
    Thank you
  4. Sep 8, 2023 at 9:20 AM
    Yup. The whole "you gotta pay to play" thing applies to modding the trucks. It is seldom a quick and easy and frequently just wanting to add something simple requires two or three other things to be changed, added, or otherwise modified.
  5. Sep 8, 2023 at 5:30 PM
    romanlegion
    romanlegion New Member
    Roman
    Katy, TX
    2022 Tundra SR5 TRD Off-Road Lunar Rock
    I have a 0-offset and my 37s are poking out about 1.5". You can expect your tires to be poking out closer to 2.25", which is too much in my opinion. I am actually switching over to a +25 to have better scrub radius to avoid tires rubbing on the fenders and fender liners.
    ytank1[OP] likes this.
  6. Sep 8, 2023 at 5:57 PM
    Tom
    Tom New Member
    0 offset is about 2.4” out for 3gen Tundra. But you got 10” wide so probably 3.5-4” each side. But if you look at the whole stance it’s 7-8” wider track. You can’t get into single car garage door for reference. Gonna need 6” lift to make it look right unless you rolling low.
