Wheel offset for chains
Discussion in '3rd Gen Tundras (2022+)' started by pyrotechnic, Apr 23, 2023.
  1. Apr 23, 2023 at 8:22 AM
    pyrotechnic
    pyrotechnic [OP] New Member
    2022 SR5 TRD OR
    Has anyone successfully ran chains on both front and rear yet? I'm planning on getting some wheels with lower positive offset to allow for enough clearance and hoping someone already has found a combination that works. From what I've seen alot of the aftermarket wheels also end up being wider than the 7.5" oems so that eats into the clearance provided by the lower offset.
    Thanks!
    FI460 likes this.
  2. Apr 23, 2023 at 9:14 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    You could try getting some TRD wheels for a Taco. They are 17x7 and not too sure of the offset but they will certainly stick out further than the Tundra OR wheels. I saw a set on Ebay or Sparks I think.
  3. Apr 23, 2023 at 9:24 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    I’ve gone deep snow wheelin and rear chains was all I needed.
  4. Apr 23, 2023 at 9:39 AM
    DMackler
    DMackler New Member
    Dustin
    Burleson, Texas
    2023 Celestial Tundra CM TRD OR
    Some TRD Pro takeoffs would help, slightly lower offset without a lot of extra width. Not my first choice, but some wheel spacers on the factory wheels would give lots of space
  5. Apr 24, 2023 at 7:40 PM
    pyrotechnic
    2022 SR5 TRD OR
    Thanks for the responses. I'd like to stay away from wheel spacers. I'm not in a big hurry, so hopefully some skinnier wheel options will pop up. I think the BBS pro wheel adds an inch of width and only a half inch of difference in offset, so the backspacing is going to be identical.
