Wheel compatability
Discussion in 'Wheels & Tires' started by Garbero, Jun 18, 2020.
  1. Jun 18, 2020 at 7:53 AM
    Garbero
    Garbero [OP] 2007 Tundra
    Jeep Wrangler.....Tundra Soon!!!
    Thanks in advance.
    Will a 2011 Tundra's wheels fit on a 2007 Tundra?
    Mountun Goat likes this.
  2. Jun 18, 2020 at 7:56 AM
    ZeRussian
    ZeRussian New Member
    ‘11 CrewMax
  3. Jun 18, 2020 at 8:13 AM
    Garbero
    Thanks, and I just look at the bottom of the site and found that same info. Switching out summer and winter tires gets expensive if you have to remove them from the same rim every year.
    Cheers, and stay healthy!
  4. Jun 18, 2020 at 8:48 AM
    ZeRussian
    ‘11 CrewMax
    If you are going that route, don’t forget about TPMS sensors unless you want to drive around with the light on one of the seasons. Also, truck has limitation on how many sensors can be programmed, so you won’t be able to store IDs for all 8 and will need to have radio IDs updated when you switch rims/tires. This can be done through Techstream or a tire shop.
  5. Jun 18, 2020 at 10:30 AM
    Garbero
    Good to know. I'm getting a smoking deal for some stock rims with tires for $60, and that's for 4. They will get a bit of the rattle can olive drab.
