Wheel/brake issue
Discussion in '2.5 Gen Tundras (2014-2021)' started by Thauglor, Sep 11, 2016.
  1. Sep 11, 2016 at 6:19 PM
    Thauglor
    Thauglor [OP] New Member
    2016 Tundra
    Non
    Hi everyone,
    New guy to the forum. Have a question for you before I take my truck to the dealership.
    Today I had to brake hard on the freeway to avoid an accident in front. Everyone was ok in it and nothing happened to us, luckily.
    Afterwards, when I used the brakes we heard a clunking noise. When we got home my son took the video below.
    The truck has about 3500 miles, barely 1.5 months old. It has a dealership applied lift and leveling kit, wife and I do not know much about lifting trucks.
    Can anyone point me in the right direction? Thanks!
  2. Sep 11, 2016 at 6:33 PM
    I would bet your lower control arm cam bolts came loose. I would check that out. If you have a 22 or 24MM socket, you can check it yourself.
    bandit likes this.
  3. Sep 11, 2016 at 8:55 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    There's a possibility the dealer installed lift was poorly done. Either way it's under warranty and they will fix it. I would not wrench on it, they might blame you.
    Let us know what happens. Welcome to the forum.
    T-Rex266 likes this.
  4. Sep 11, 2016 at 9:00 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Welcome to the forum. Something definitely came loose when you braked hard. Lots of things it could be. Def suspension related and not the brakes.
    bandit likes this.
  5. Sep 11, 2016 at 9:49 PM
    I also might consider a tow truck. Safety first.
    Thauglor[OP] and bandit like this.
  6. Sep 12, 2016 at 5:39 AM
    bandit
    bandit New Member
    2011 Supercharged Mazzulla Long Travel Rock Warrior
    Duh Tundra
    Welcome! That actually is a exact mimic, sound and pop of what happened to my truck when I broke the CV's at pismo. Look under the truck behind the tire itself and start grabbing things and shaking them. That should at least get you going in the right direction but something is clearly broken.
    My bet is on the CV. It's exactly what mine did once I got it on pavement. And there's nothing else rotationally that can make that popping noise from the front end.
  7. Sep 12, 2016 at 5:40 AM
    bandit
    bandit New Member
    Duh Tundra
    This would be the best thing to do, especially if you're not mechanically inclined in the lifted truck world.
  8. Sep 12, 2016 at 5:43 AM
    bandit
    bandit New Member
    Duh Tundra
    I had the cam bolts come loose on mine, it did make a slight popping noise but not to the extent of his video. The CV's binding up then the force rotating them past the bind causing them to brake free and roll forward again, then bind up and repeat is the only thing I've experienced that created a replica of his video. I'm curious to hear what the dealer says the issue is though!
  9. Sep 12, 2016 at 6:22 AM
    Let the dealer take it. Their responsibility for install of it.
    NewImprovedRon and bandit like this.
  10. Sep 12, 2016 at 6:58 AM
    Thauglor
    2016 Tundra
    Non
    Thank you everyone! No bolts were loose that I can see. Good call on the tow truck, didn't even think of that, time to use the free roadside service to get it there.
    Thanks!
  11. Sep 12, 2016 at 7:53 AM
    bandit
    bandit New Member
    Duh Tundra
    Shake the front axles.
    ColoradoTJ likes this.
  12. Sep 12, 2016 at 10:44 AM
    Keep us posted on what is found. That would be disturbing if hard braking broke the CV shafts.....
    bandit likes this.
  13. Sep 12, 2016 at 11:52 AM
    Thauglor
    2016 Tundra
    Non
    It is at the dealership and we got a rental. Will update the thread when I know more. The service manager himself drove it and took it back to the service station.
  14. Sep 12, 2016 at 1:01 PM
    GoHuskers
    GoHuskers New Member
    Nebraska
    '24 iForceMax, '17 RX350, '15 GX460
    Glad you and your family were OK. Please keep us posted.
  15. Sep 12, 2016 at 1:18 PM
    bandit
    bandit New Member
    Duh Tundra
    Did you see his video and the loaded up tension releasing? What else could create that besides CV's binding up.....That would seriously suck though I agree.
  16. Sep 12, 2016 at 3:03 PM
    Alignment Cam bolts would be my answer. Will be interesting to hear what they come up with or some BS they give them.
    Abrams65 and bandit[QUOTED] like this.
  17. Sep 12, 2016 at 7:10 PM
    Mike Tread lightly.
    south carolina
    Cam bolts could also be ball joint failure even tie rod... More or less improper torque specs where used causing the failure and my bet is on that unless shady lift was used...
  18. Sep 15, 2016 at 5:18 AM
    Any updates on this issue OP?
  19. Sep 16, 2016 at 9:08 AM
    Thauglor
    2016 Tundra
    Non
    The dealership sent the car over to the shop that did the lift for them. Paperwork says they just tightened all suspension components and checked alignment. We will see if it comes back or not.
