Wheel bearing short cut
Discussion in '1st Gen Tundras (2000-2006)' started by mbreed2, Jul 20, 2021.
  1. Jul 20, 2021 at 11:00 AM
    mbreed2
    mbreed2 [OP] Is not right
    Allentown PA
    2001 Tundra 4x4
    Someone posted under Timmy's video for bearing removal with a press and special adapter. I can't make sense of what the commenter is doing.
    Anyone do it this way, or can make sense of it?
  2. Jul 20, 2021 at 11:46 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    If I understood correctly, he removed 2 studs (lugs) from his hub, used a plate and ran bolts through the holes in the hub where studs were. Then use the nuts on the bolts to push the plate down one side at a time until it is pressed in.
    Edit- just saw he says this pushes them out. I doubt he could get enough force this way but maybe he did.
    That sounds like a lot of trouble and an easy way to f it up. Better off to collect the parts and find a shop willing to do the press work. The bearings are in very tight, some guys get lucky and do it at home with a press, others said the hub laughed at their press.
    I found a shop near me who charged me $100 per hub and did a good job. Beats what Toyota wanted. I brought him the spindle assemblies and parts loose, he did the hard part. Toyota wouldn't touch my truck because I run aftermarket upper arms and they refused to work on loose parts if I brought just the spindles.
  3. Jul 20, 2021 at 11:49 AM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    Bingo. Exactly what I did. I brought them my hubs all nice & cleaned up and they were happy to do it. Only one shop up here that I know of that has the Toyota adapter too.
    des2mtn and Darkness[QUOTED] like this.
  4. Jul 20, 2021 at 11:59 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    There's definitely shade tree mechanic ways to do rear axle press work. I pulled the axles out of the truck and paid $180 at a machine shop to have both of mine done. I brought my own OEM parts. They disassembled them and put it all back together.
    Is your truck ABS? Getting the ABS tone ring pressed to the right spec is something to consider when putting it all back together.
    Is this maybe what they're thinking of?
    Darkness, Sirfive and FrenchToasty like this.
  5. Jul 20, 2021 at 12:03 PM
    mbreed2
    Allentown PA
    2001 Tundra 4x4
    Yeah I'm starting to see the concept. This guy puts it to practice on a Ford. Different rear end set up but I think the concept is the same.
    https://youtu.be/p9543-dMBRo
  6. Jul 20, 2021 at 12:03 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Oh shot is he talking about rear wheel bearings? Thats a different story. I read the post but didn't look at the picture :rofl:
  7. Jul 20, 2021 at 2:00 PM
    mbreed2
    Allentown PA
    2001 Tundra 4x4
    This is frustrating. Local independent shop has the set up for it, but refused to work on it because I already have the axles out...
    I have a good press at work. Just didn't want to spend money on a $100 tool that has one purpose and I am going to use once.
  8. Jul 20, 2021 at 2:03 PM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Swing press wont work?
  9. Jul 20, 2021 at 2:06 PM
    mbreed2
    Allentown PA
    2001 Tundra 4x4
    Trying not to gnar it up too much.
    Sirfive likes this.
  10. Jul 20, 2021 at 2:08 PM
    mbreed2
    Allentown PA
    2001 Tundra 4x4
    I actually had it blocked up and was hitting the axle with a dead blow. That collar laughed it off.
  11. Jul 20, 2021 at 2:08 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Sounds like @bmf4069 needs to start a tool rental progamme like I’ve got going
    bmf4069 and Darkness like this.
  12. Jul 20, 2021 at 10:28 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Yeah, I've got the bearing thing if someone needs to borrow it. I'm not sure how to use it though. Maybe someone smarter than me can finger it out.
    Darkness and des2mtn like this.
  13. Jul 21, 2021 at 4:32 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    I also have the tool. I've used it and it works really well.
    Timmy the Tool Man's instructional video shows every step in detail.
    @mbreed2 I don't understand the comment to the video either. I don't know how I'd have done it without the tool. I've loaned mine to another member on this site and it worked out well. He gave me a deposit, and paid shipping both ways. I refunded his deposit when he returned the tool. I'd be willing to do it again, but it's going to cost you a little over $20 each way to ship it -- so $40+ total. PM me if you're interested.
    Frankly, the lack of shop press is the limiting factor for most folks. If you have access to one at work, you're halfway home.
    If the price of the tool has come down to $100, I think it makes more sense for you just to buy your own, do the job, and sell it to the next guy for $60.
    Again, I'm happy to loan it. Your call.
  14. Jul 21, 2021 at 1:42 PM
    mbreed2
    Allentown PA
    2001 Tundra 4x4
    Des2mtn has the right idea in the picture. I tried it that method this morning. All I can say is, grade 5 bolts broke before they moved that collar.
    I have the adapter on order. Less than 100 shipped. And I have access to a press at work. I just didn't want to wait another week to finish the job.
    bmf4069 and des2mtn like this.
  15. Jul 21, 2021 at 9:28 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Sweet. Grab pics and keep us updated.
