Wheel Bearing - Need Your Professional Thoughts
Discussion in 'Suspension' started by Les7311, Oct 8, 2017.
  1. Oct 8, 2017 at 8:15 AM
    Les7311
    Les7311 [OP] Look up, what do you see
    2008 Blue Tundra TRD 4x4
    ....So my right front side wheel bearings went, and (home) surgery is in the makings.
    Truck Profile: 2nd Gen, 5.7, 4WD, 126K miles, 6 inch Lift, 35's
    Which one of the below is highly recommended?
    1. Replace bearings by Press-out (buddy charging a nominal price to press in)....bearings from a local store $50 each,
    or,
    2. buy a pair online for $320 that comes with full hub and bearings
    Any help for thoughts as I want to buy today.
    thanks
  2. Oct 8, 2017 at 11:25 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    Just my 2 cents, but I think the complete hub assembly is the easier way to go. Less disassembly, reassembly and down time. I guess it comes down to whether you have more time or money... I usually have more time :( lol. Either way, I would do both sides at the same time and be done with it.
  3. Oct 8, 2017 at 11:30 AM
    Complete assembly is the route I would go.
    Les7311[OP] likes this.
  4. Oct 8, 2017 at 12:45 PM
    Les7311
    Well said my fellow Tundrians!!
    The ordering has begun!
    ColoradoTJ and 4x4_Angel like this.
  5. Oct 8, 2017 at 1:15 PM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    i did this to my 4r and went with the assembled package - i liked the new wheel studs too...
    also. i have a full size press but these are buggers to remove even with a press... buying the assembly made it a really quick job
    Stormtrooper81 and ColoradoTJ like this.
  6. Oct 8, 2017 at 1:39 PM
    Les7311
    Yeszzrrrrr!
    Bet!
  7. Oct 8, 2017 at 2:30 PM
    Tundraplatinum
    Tundraplatinum New Member
    2016 Platinum CM
    Go complete assembly but buy dorman brand part number 950-002 they have them on ebay for $133 each look around you might find better deal. Dorman is decent quality that's what we use at my shop
  8. Oct 8, 2017 at 2:31 PM
    Tundraplatinum
    2016 Platinum CM
  9. Oct 8, 2017 at 2:49 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    My 2 pennies, buy Timken. They're typically more expensive but worth it.
  10. Oct 11, 2017 at 4:26 PM
    Les7311
    Look what came today. And it’s the same item on eBay, same seller, but $150 less on Amazon
  11. Jan 7, 2019 at 8:38 PM
    Bmxrider1331
    Bmxrider1331 New Member
    Brendan
    NEW JERSEY
    2013 tundra 4x4 4.6....
    3 inch toytec eibach kit on 35s
    I'm sorry to wake an old thread but I have to know of what you bought ^^^ and the dorman link along with the Amazon was a direct bolt on?I need both along with doing my ball joints. Thank you in advanced
    Les7311[QUOTED][OP] likes this.
  12. Jan 8, 2019 at 3:35 AM
    Les7311
    Well let’s see again.... Krill Oil haven’t kicked in yet! Ahemmmm.. cough. Cough..
    Item still on Amazon.
    I purchased the full assembled wheel bearings hub, instead of the press on bearings.
    And correct it’s a direct bolt / install / replacement. Passenger side wheel (35’s) were shot. Hope this help - hola!
  13. Jan 8, 2019 at 6:33 AM
    Bmxrider1331
    Brendan
    NEW JERSEY
    Hey thanks so much just making sure my apologies. I bought a wheel bearing already to install and it was just a pain in the ass. I had to cut my losses but this seems perfect. I think I might go head and replace my ball joints and axles aswell. THANK YOU
  14. Jan 8, 2019 at 7:20 AM
    Les7311
    Thanks and keep us posted
