Wheel Bearing/Hub?
Discussion in '2nd Gen Tundras (2007-2013)' started by Kfxnow, Apr 9, 2023.
  1. Apr 9, 2023 at 11:58 AM
    Kfxnow
    Kfxnow [OP] New Member
    Joel
    2008 DC 4x4 lifted
    2008, 169k miles, 6 in lift with 37s. Great truck. I've already done the roller bearing carrier in the front diff. Everything was smooth after that. Couple thousand miles ago, I get a loud growl from about 45-70. Using 4WD doesn't make it go away. Rotated the tires, no change. When I'm turning right the noise temporarily goes away. Hitting a small bump will make it go away. Jacked up the front end, no play in either of the wheels....solid. However, it does seem like the driver side wheel/tire may drag a bit more than the other side when I spin them by hand. I'm thinking Wheel bearing (shoulda done while I was in there with the roller bearing). Anyway, these seem to be the best. https://www.ebay.com/itm/164409484004 I only need one and it comes in pairs. Anyone need a wheel bearing/hub and I'd sell the other one to you.
  2. Apr 10, 2023 at 11:32 AM
    KeepOnTruckin
    KeepOnTruckin New Member
    Randy
    2010 4.6 4x4 Bare Bones
    Do keep in mind that the right side completely disconnects from the diff (dog style gear) while the left side is spinning two side gears and the spiders so, it will have more drag.
  3. Apr 10, 2023 at 11:41 AM
    Kfxnow
    Joel
    2008 DC 4x4 lifted
    That 'feels' about right. The drag wasn't considerable on the driver side. So perhaps this is NOT a wheel bearing?
  4. Apr 10, 2023 at 11:43 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Since the noise goes away with a slight turn, it sounds like it is the bearing. I did mine the old school way with a shop press, but that seller on Ebay is the way to go for sure.
  5. Apr 10, 2023 at 11:47 AM
    Kfxnow
    Joel
    2008 DC 4x4 lifted
    Great! Thanks!
  6. Apr 10, 2023 at 3:36 PM
    4x4WarriorOfRocks
    4x4WarriorOfRocks New Member
    2010 Tundra 4x4 Rock Warrior
    Just my opinion, but I recommend these:
    https://bluepitbearings.com/product...dra-4x4-koyo-oem-front-wheel-bearing-assembly
    Andy Taylor (company owner) is extremely knowledgeable and helpful. He called me after I messaged him when I was having questions while installing, and he spent a couple hours on the phone with me. That kind of service is worth the money to me alone. It also happens to be a great product! Lol
    Anyways, mine feel great since the install, which was about 10,000 miles ago.
  7. Apr 10, 2023 at 4:03 PM
    Kfxnow
    Joel
    2008 DC 4x4 lifted
    Thanks for the option!
    4x4WarriorOfRocks likes this.
