Wheel Bearing & Hub Assembly for Tundra
Discussion in '2nd Gen Tundras (2007-2013)' started by joseph_womack, Nov 27, 2020.
  1. Nov 27, 2020 at 2:51 PM
    joseph_womack
    joseph_womack [OP] @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    Any recommendations on what brand to get for a front passenger hub? My hub is bad and I'm trying to figure out which brand to go with... Ideally I would want to get a new bearing & hub assembly because that would be quicker and easier?
    (2007 Tundra 4WD - if that matters)
  2. Nov 27, 2020 at 8:12 PM
    ICECOLDBEER
    ICECOLDBEER New Member
    2009 Toyota Tundra TRD Off Road 5.7 4x4 Double Cab
    I would try to figure out who supplies the OEM Toyota bearings. And see if you can get them through local parts store. I'm not sure who supplies them though. Never had to replace my Toyota truck wheel bearings. Knock on wood... But on other vehicles have had bad luck with aftermarket stuff. Definitely don't cheap out on it IMO. I liked this guys video---> https://www.youtube.com/watch?v=rJ3gL6PIy2c&ab_channel=ViktorG
    joseph_womack[OP] likes this.
  3. Nov 27, 2020 at 9:14 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    OEM are made by Koyo, and SKF are / were Koyo bearings inside the SKF box.
    But both of those are the bearing without the hub, that needs to be pressed apart / together.
  4. Nov 28, 2020 at 9:21 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    I know Napa has OEM Nachi brand (made in Japan) for the rear. Might see what they have. Def recommend OEM like others.
  5. Nov 29, 2020 at 10:47 PM
    joseph_womack
    Joe
    Louisiana
    So buying the complete hub assembly is just smarter because it wouldn't be as much of a hassel?
  6. Nov 29, 2020 at 10:47 PM
    joseph_womack
    Joe
    Louisiana
    Thanks for the video and recommendations!
  7. Nov 29, 2020 at 10:48 PM
    joseph_womack
    Joe
    Louisiana
    Thanks for the help!
  8. Nov 29, 2020 at 11:01 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Definitely easier for a DIY'er without a press.
  9. Nov 29, 2020 at 11:16 PM
    joseph_womack
    Joe
    Louisiana
    Are we talking a particular press or for this or just any press, haven't watched any videos yet
  10. Nov 30, 2020 at 5:50 PM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    How did you know your wheel bearing was bad.
  11. Dec 1, 2020 at 9:02 AM
    joseph_womack
    Joe
    Louisiana
    Brought it to a tire shop for an alignment and the guy there told me, I jacked the truck up when I got home to try and see if I can wiggle the wheel up and down but I can't, I'll take off the wheel and rotor later and see if I can wiggle it later. Might call Toyota and see if they will check the alignment on the truck and hub for free... but ya know stealership
  12. Dec 2, 2020 at 10:28 AM
    Vince
    Vince New Member
    Vincent
    I just ask I have some tire cupping was wondering if you noticed something. Thank you for the reply
  13. Dec 2, 2020 at 6:16 PM
    joseph_womack
    Joe
    Louisiana
    No problem, apparently its like a hum/kinda droney sound
