Wheel bearing, axle seal, diff vent or all the above
Discussion in '1st Gen Tundras (2000-2006)' started by Ak907, Aug 4, 2021.
  1. Aug 4, 2021 at 6:36 PM
    Ak907
    Ak907 [OP] New Member
    Travis
    Anchorage
    2002 Tundra SR5 4x4 access cab
    Aluma 2.0 boss coil overs, Jba upper control arms, airbag rear suspension with AAL
    So been doing lots of work on the rig I’ve owned now for almost 16 years. Really been needing a lot of suspension drive train work. I noticed couple weeks back my passenger rear tire had some oil on it. First inspection i thought maybe it was a break cylinder since I didn’t smell any diff oil. Took er apart today and holy cow what a mess. Oil and grease everywhere, I’m not sure if it’s diff fluid or bearing grease or most likely a combination.
    So I’m wondering if someone can maybe help me diagnose this since I’m not a bearing specialist. Could it just have been a clogged vent or does it look like it’s shot??
    https://youtube.com/shorts/L0RAUm7PgBE?feature=share
    here is the video of wheel bearing.
  2. Aug 4, 2021 at 7:04 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Ak907[OP] and FrenchToasty like this.
  3. Aug 4, 2021 at 8:45 PM
    Ak907
    Travis
    Anchorage
    Hey thanks for the reply. Just helpful to have another opinion since this isn’t exactly my career! I do love my truck and taking care of it but man does it’s age require some nursing. You think I should replace the axle seals while I’m at it? The reason I ask is because id hate to replace something that isn’t broken since some of the crap parts their putting out nowadays is not worth replacing it with.
    I just did my from cv axles and the drivers side was leaking. Replaced the seal with a National and some cv half axles from orielys. Still leaking, jeeezzzz.
  4. Aug 4, 2021 at 9:10 PM
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    Doing the seals while you're there would be wise. Use the OEM Toyota for best results and fitment.
    Lil Steve, FrenchToasty and bmf4069 like this.
  5. Aug 4, 2021 at 9:28 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    The seals usually come with the bearing kit. They're the little fellas hanging out in the axle tube. It'd be a sin not to replace them while the axles are out.
  6. Aug 9, 2021 at 3:55 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    What happened to your retainer ring in the second pic? Why is it all beat up and marred on the edge?
    des2mtn and w666 like this.
  7. Aug 9, 2021 at 8:05 AM
    Ak907
    Travis
    Anchorage
    this is a great question. I changed these rear wheel bearings about 5ish years ago though a shop. So I’m guessing that’s them hammering it on. I can’t imagine it was damage caused by driving, looks to much like hammer and miss placed hammer marks. Unless you got a better guess? Haha
  8. Aug 9, 2021 at 3:20 PM
    Ak907
    Travis
    Anchorage
    So got the new bearings in the mail today. They look great but Immediately noticed they have relatively same amount of wiggle/rotational play in them brand new from the box. I guess I just need to assume it was the bearing that tossed grease everywhere. Just had them replaced like 5 years ago. Not sure what the live span on these is.
  9. Aug 9, 2021 at 4:19 PM
    tvpierce
    Maine
    I think you're right.
  10. Aug 9, 2021 at 4:24 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    If the axle seal failed, the gear oil will get into the bearing and change the viscosity of the grease til it leaks out and eventually fails.
    Also that bearing race looks like they used an air hammer and chisel to install it. No bueno. It may have nicked/damaged the seal when they slid it in.
    des2mtn likes this.
  11. Aug 13, 2021 at 8:59 PM
    Ak907
    Travis
    Anchorage
    yeah I’m actually convinced the bearing is actually intact. I think because the rear differential vent was blocked, this caused all the oil to get tossed out the seal and all over the brakes. I’ve got new bearings that I’ll replace even though I’m not looking forward to it. Also bought new brake shoes. I’ve since pulled it apart before the new parts arrived and cleaned them all up. It doesn’t appear to be leaking anymore since I’ve cleaned out the vent.
    I’ll reluctantly change out the bearings and the needed brake shoes since they probably don’t work worth a crap with gear oil saturated in the pads. Thanks for all the replies guys. Appreciate everyone’s help and suggestions.
  12. Aug 14, 2021 at 2:10 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I'll second what @assassin10000 said on the bearings. I had an axle seal go out and gear oil seeped into my wheel bearing. Ultimately the bearing grease was eaten up by the gear oil and the internal bearing cage ripped apart. Good luck!
    bmf4069 likes this.
