Wheel and setup help
Discussion in 'Wheels & Tires' started by THErealHD, Apr 26, 2022.
  1. Apr 26, 2022 at 7:33 AM
    THErealHD
    THErealHD [OP] New Member
    2007 tundra trd limited
    Hello so I have decided to go 18s with +25 icon offset 295/70 Falken at3.. I was wondering i am on 07 tundra trd stock... is there anything else I need to do to fit this package or can I put them on with stock height
  2. Apr 26, 2022 at 8:26 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Stock, 295s can fit, is very stuffed look. You will need to lose the front air flaps, maybe need to remove mud flaps, and may need to heat and clearance the wheel well liner. Ive seen stock trucks with 295 and +25 wheels, so it can work. Most run a level at least, 2 inches lift when running those size tires.
    THErealHD[OP] likes this.
  3. Apr 26, 2022 at 10:42 AM
    bmtrujillo98
    bmtrujillo98 New Member
    I run 35x12.5x18 (really 34.5) on my Method 701 18x9 +25mm offset wheels... Was rubbing a bit on the front fender liner (after removing air dam) but decided to go with a steel front bumper to get a better approach angle off-road and eliminate all the rubbing. I also run a 3/1 lift. I would say 295/70/18 is hit and miss on stock trucks, I would consider a leveling kit at the very least and even then be prepared to reshape your fender liner with a heat gun and remove the rear mud flaps. A big part of fitting oversized tires on our trucks is getting a good alignment. Take it to a reputable 4x4 shop.
