Wheel advice and hauling boat without sagging
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tejas Pete, Feb 12, 2019.
  1. Feb 12, 2019 at 10:52 PM
    Tejas Pete
    Tejas Pete [OP] New Member
    Pete
    2016 CrewMax Limited 4X4
    Bought my Tundra Limited crewmax new in 2016 and now it’s time for new tires. I decided I wanted bigger tires and a two inch level in the front. I’m going with Fabtech leveling kit. I’m swapping out my 20” wheels for 18x9 wheels and I wanted to put 325/60/18. The problem I’m having is no one can tell me which offset for the new wheels. I have been told anything from a 1 to -18 offset. I saw the same tires on another Tundra and the truck looked perfect but didn’t get a chance to ask the owner modes lift etc, etc
    I have been told I need a wider wheel that an 8” but all the specs say I can put a 325/60/18 on a 18/9. True and if so is it smart or should I go 18 x 10?
    The next issue is I pull my boat (24’) and I don’t want any sag. I have had several guys tell me to get bags for the rear. I don’t want a big tank does anyone have any other options suggestions
    Thanks!
  2. Feb 12, 2019 at 11:21 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    You don't need a big air tank for Firestone ride rite air bags. I've got a set on my truck, I fill them with a small air compressor and roll. Or you can spend a little more and get the kit that comes with a small air compressor and you can fill them from inside the cab. Makes towing sooo much better. Well worth the money.
    OR18TRD likes this.
  3. Feb 12, 2019 at 11:23 PM
    easleycrawler
    Travis
  4. Feb 12, 2019 at 11:27 PM
    easleycrawler
    Travis
  5. Feb 12, 2019 at 11:29 PM
    easleycrawler
    Travis
    This is mine with 40psi.
    OR18TRD likes this.
