Wheel +20 vs +1 offset
Discussion in 'Wheels & Tires' started by monaco730, Mar 30, 2018.
  1. Mar 30, 2018 at 8:36 AM
    monaco730
    monaco730 [OP] New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    Does anyone have any pictures of their +20 or +1 offset wheels? I am between the two offsets but not sure which to get. Thanks for your help.
  2. Mar 30, 2018 at 8:42 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Mike I don't have either one , but for the difference between the 2, it's about 3/4". Your +1 offset will push that tire out more. Also depends on size tire your running to. Hope this helps
  3. Mar 30, 2018 at 8:48 AM
    monaco730
    16 Inferno Tundra
    Thanks @rons23 . I am debating between 285/70/18 and 295/70/18. I believe the stock offset is 60mm. So if...
    60mm = 2.3622 inches
    20mm = .7874 inches... this will push it out 2.3622 - .7874 = 1.5748 inches
    1mm = .0394 inches... this will push it out 2.3622 - .0394 = 2.3228 inches
    ...so the difference between the two....2.3228 - 1.5748 = .748 inches...which is basically 3/4" like you said. Smart guy you are :)
    wayoutwanderer, jptshadow and Sas like this.
  4. Mar 30, 2018 at 8:55 AM
    rons23
    Ron
    Kill Devil Hills
    Na Mike I'm a perpetrator, haha. I'm running 295/70/18 Ridge Grapplers with 1.25" Spider Trac spacers. Not my long term solution, but it's the perfect stance for me.
    zcarpenter92 likes this.
  5. Mar 30, 2018 at 8:56 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    I believe the +20 will push inward not out as you stated. The negative offset pushes out, positive pushes in.
    mudslinger79 likes this.
  6. Mar 30, 2018 at 8:57 AM
    monaco730
    16 Inferno Tundra
    I will be getting the RGs as well. How you liking those? I've heard nothing but great things.
    So the 1.25" is 1/4" less than the 20mm. Can you show me a picture of your truck stance?
  7. Mar 30, 2018 at 8:59 AM
    monaco730
    16 Inferno Tundra
    +60 is stock, so if i go to +20 or +1, that is actually going "negative" but it is still a positive offset. Picture....
    0 offset (center) --> +1 --> +20 --> +60 ..... so the +1 and +20 are "less offset" even though they are a positive offset
  8. Mar 30, 2018 at 8:59 AM
    chphilo
    chphilo Tundra addict
    Western PA
    If you go with 9 inch wide wheels, half of 1 inch will push the wheel further out than the stock 8 inch wide wheels.
    Go with 20 mm. If you go with 1 mm offset, you will most likely have to cut the body mount (part of the frame) with anything larger than 33 inch diameter tires (which includes both sizes you mentioned).
    Here is picture of how much the stock tires (275/65/18) on 18 mm wheels stick out. Fender flares sits 1.75 in further out than the truck body.
    monaco730[OP] likes this.
  9. Mar 30, 2018 at 9:01 AM
    monaco730
    16 Inferno Tundra
    Thanks @chphilo ... i am thinking 20 as well as i think the 1 will stick out too much. I appreciate your feedback.
  10. Mar 30, 2018 at 9:01 AM
    Trooper2
    JR
    Gotcha :thumbsup:
  11. Mar 30, 2018 at 9:03 AM
    rons23
    Ron
    Kill Devil Hills
    Loving them so far. I can't give a fair review as they only have 2k miles, but looks and quietness are great. Here's a pic, not the best
  12. Mar 30, 2018 at 9:04 AM
    monaco730
    16 Inferno Tundra
    Exactly what i was looking for @rons23 thank you
    rons23[QUOTED] likes this.
  13. Mar 30, 2018 at 9:06 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Agreed on the RG’s. I only have 4K miles on mine, same size.
    rons23[QUOTED] and monaco730[OP] like this.
  14. Mar 30, 2018 at 9:08 AM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
  15. Mar 30, 2018 at 9:11 AM
    monaco730
    16 Inferno Tundra
    rons23 likes this.
  16. Mar 30, 2018 at 9:16 AM
    rons23
    Ron
    Kill Devil Hills
    Anytime Mike
  17. Mar 30, 2018 at 10:05 AM
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    These are 295/65's on a +25offset wheel. a +1 offset would push the wheel out another .94 inches.
  18. Mar 30, 2018 at 10:06 AM
    Opus5150
    Opus5150 Terminal Lance
    Live Free or Die
    2017 Tundra
    My two cents - Fuel Trophy +20 with 275/70 R18 Nitto RGs.
  19. Mar 30, 2018 at 10:08 AM
    monaco730
    16 Inferno Tundra
    I am looking at the fuel vectors 285/70/18 so this is almost the set up im looking at and i think the +20mm is the way to go. Thank you!
  20. Mar 30, 2018 at 10:12 AM
    monaco730
    16 Inferno Tundra
    I like your stance. I think 285's with +20 would be very close to your stance. Thanks!
    sr5shark[QUOTED] likes this.
  21. Mar 30, 2018 at 10:12 AM
    ToyotaTundraMike
    2015 Tundra
  22. Mar 30, 2018 at 10:39 AM
    monaco730
    16 Inferno Tundra
    Are you suggesting +20 over +1? If so, what makes you have that opinion?
  23. Mar 30, 2018 at 10:51 AM
    ToyotaTundraMike
    2015 Tundra
    Couple reasons.
    It has been widely noted on the site that +18 to +30 is the “sweet spot” for our trucks. This offset range requires the least amount of modifications to prevent rubbing.
    It sticks out nicely no matter which tires you have for an aggressive look, but not obnoxious like you see with the guys that have a half foot of tire showing past the fender. This means you can get by without adding flares if you don’t want to.
    monaco730[QUOTED][OP] likes this.
  24. Mar 30, 2018 at 10:52 AM
    monaco730
    16 Inferno Tundra
    This is good info. Thanks Mike!
  25. Sep 24, 2018 at 5:14 PM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    Sorry to revive this thread, but I'm also considering 18" Fuel rims with a +20 offset. When you say you can get away without fender flares, how much do you have to worry about stuff getting flung up on the paint? I love the look of the +20s, but I'm just worried about ruining my paint. Fuel makes a 17" in a +35, but I'd kind of rather stick to 18" rims.
  26. Sep 24, 2018 at 5:17 PM
    TuFerLife
    TuFerLife New Member
    Taylor
    Chattanooga, TN
    2018 Tundra TRD Sport 4x4
    3" Toytec Eibach coilovers with .5" coachbuilder shims and Coachbuilder +3 shackles, JBA Upper Control Arms, Fuel Assault 20x10 -18 offset on 35x12.50 Cooper ST Maxx, Amp research stepbars, JBA Long tube headers, custom mid pipes and TRD Replacement exhaust system by Dirty Deeds, TRD Black Chrome Tailpipes, Bullit liner spray in liner, S&B CAI, Katzkin leather with Degreez heated and cooling system, Husky floorliners, Coachbuilder roof rack with 13 Rigid pods and Switchpro switch, TRD skid plate, Pop-N-Lock, Auto Tailgate down mod, Rattletrap sound deadener in headliner and door panels. Kenwood DDX 9906XR headunit with full Tech 12 volts sound system and dash cam.
    0F8974F5-B203-4770-8897-2A28E1C85443_zps_61b559f6af5d71c1d152ef3d41708856dffb67e0.jpg
    +20 on 35x12.50. Glad I didn’t go 0 offset. I still might buy OEM flares to have these not sticking out so far.
  27. Oct 14, 2018 at 3:54 AM
    Lucobrasi
    Lucobrasi New Member
    Jon
    2018 Tundra TRD Sport CM MGM
    What size lift do you have TuFerLife? Also was there any trimming involved? Thank you!
    TuFerLife[QUOTED] likes this.
  28. Oct 14, 2018 at 5:39 AM
    TuFerLife
    Taylor
    Chattanooga, TN
    Toytec eibach 3/1.5. Coilovers in the front and shackles in the rear.
    No cutting yet... I did kind of have to push the bumper forwards. I removed the screws at the bottom of the bumper, pushed it forward like crazy, and then screwed it back in.
    Still some light rub in full lock in reverse, so I probably still need to trim the liner a little bit on the botto, or use a heat gun and push it forwards.
  29. Oct 16, 2018 at 4:27 PM
    Xyleff
    Xyleff New Member
    NorCal
    ‘16040CMSR5
    Your +20 looks like it pokes more than my +12. Then again I’m on 295/70 only.
  30. Oct 16, 2018 at 4:50 PM
    TuFerLife
    Taylor
    Chattanooga, TN
    Yeah apparently there’s a formula for it. But they definitely have a poke... contemplated OEM flares to cover it up a little bit. I think pocket flares would be too much...
