Whats your method to get both rear wheels roasting?
Discussion in '2.5 Gen Tundras (2014-2021)' started by KLLVMDCL, Jun 3, 2019.
  1. Jun 3, 2019 at 3:07 PM
    KLLVMDCL
    KLLVMDCL [OP] New Member
    Brandon
    Austin, Texas
    2017 Super White DC SR5
    All nannies off/ tow haul, all nannies on or some other combination? One tire fire aint cutting it. Cheers
    Mountun Goat and Black Wolf like this.
  2. Jun 3, 2019 at 3:10 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Beast mode!
    Mountun Goat and escuzi_me like this.
  3. Jun 3, 2019 at 4:07 PM
    Death Valley
    Tundyfundy, Mountun Goat and Darkness like this.
  4. Jun 3, 2019 at 5:19 PM
    Jettech
    Jettech New Member
    Jesse
    Nashville, TN
    08' Tundra CM
    TRD Exhaust, DC 305/55/20s, TRD PRO Shocks, HID's, JOBOX, Bully Dog Tuner, TRD sway bar, Shorty FM Int,
    Nanny button push twice for all nannies disabled. Tow haul button once. Drop to D. Knock shifter to the left and drop down to manual first gear will usually do the trick.
    Mountun Goat likes this.
  5. Jun 3, 2019 at 5:28 PM
    Racingjohndeere55
    Racingjohndeere55 New Member
    Unless you have a 4.6....... ain't nothing helping
  6. Jun 3, 2019 at 5:30 PM
    15whtrd
    15whtrd Mr. Blonde
    Need a locker or Auburn. If you go on the dirt you can get them both going
  7. Jun 3, 2019 at 5:34 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Too soon :bananadead:
    I don't have to do much since my truck is black.
    NewImprovedRon and Mountun Goat like this.
  8. Jun 3, 2019 at 5:39 PM
    MGM2018OR
    MGM2018OR New Member
    Craig
    2018 MGM OR dbl cab ( gone but not forgotten )
    I don’t get my tires roasting. If I wanted that, I would buy the competition.AC035E52-1D35-4514-BBB5-450A347F3226.jpg
  9. Jun 3, 2019 at 5:39 PM
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    nannies off, in tow haul mode...... then turn on air locker, and let my 4.88 gears do work and the long tube headers and full 3" race exhaust sing..
  10. Jun 3, 2019 at 6:41 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Prostar 190 likes this.
  11. Jun 3, 2019 at 6:44 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    LSD! :spam:
    15whtrd likes this.
  12. Jun 3, 2019 at 6:48 PM
    G10dra
    G10dra Not a New Member
    Looks like the engine light is on
  13. Jun 3, 2019 at 7:04 PM
    I can actually smoke my tires if I want to but would be way better with a real locker or LSD....dang ....LSD... heh...heh...
  14. Jun 3, 2019 at 7:05 PM
    "FIRE" ON ROAD DEAD!!
  15. Jun 3, 2019 at 7:44 PM
    15whtrd
    15whtrd Mr. Blonde
    Mine is pretty much a one tire fire. Or it just hooks up and just hazes them.
  16. Jun 3, 2019 at 7:46 PM
    deedubb
    deedubb New Member
    David
    2018 Tundra SR5
    The best way is to red line it and slam the tranny into drive :anonymous:
  17. Jun 3, 2019 at 7:46 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Show off lol
    papasmurf[QUOTED] likes this.
  18. Jun 3, 2019 at 8:34 PM
    Yep...one tire fire.....there is that issue........
  19. Jun 3, 2019 at 8:35 PM
    Kuul....:burnrubber:
  20. Jun 3, 2019 at 8:38 PM
    Duneflyer
    Duneflyer MGM is the light at the end of the tunnel
    Darren
    Yuma AZ
    2017 1794 edition Crewmax 4x4
    Nitro 4:88 gear package with locker in rearend, Procomp 6" lift, mid travel arms, with devers on back, Fox 2.5 coilovers
    I just put it in drive and gas it.. tho my super charger, with 4.88 gears and LSD help spinning my 35" tires.
    papasmurf, Prostar 190 and Black Wolf like this.
  21. Jun 3, 2019 at 8:40 PM
    Well there is "that" to improve "things" a bit................:burnrubber::burnrubber::burnrubber::burnrubber::burnrubber:
    Duneflyer[QUOTED] likes this.
  22. Jun 4, 2019 at 12:58 AM
    KLLVMDCL
    Brandon
    Austin, Texas
    that's the thing, I have a 4.6 and I can get a rip going in 1st with all nannies off, but judging by my tread wear its only one tire fire. just wanted to see if anyone had any tricks
  23. Jun 4, 2019 at 3:22 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
  24. Jun 4, 2019 at 3:52 AM
    Racingjohndeere55
    Trade it in for a 5.7 that will do it
  25. Jun 4, 2019 at 4:03 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    At $320/tire, i aint even trying to roast em.
  26. Jun 4, 2019 at 4:38 AM
    :popcorn:
    papasmurf likes this.
  27. Jun 4, 2019 at 4:57 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Exactly, tires are expensive!
    I did it once to confirm that it would light up both tires, it did and that's good enough for me.
  28. Jun 14, 2019 at 4:50 PM
    KLLVMDCL
    Brandon
    Austin, Texas
    Lmao I could imagine the look on my old ladys face when I told her I traded in my truck for a new one to do burnouts.
  29. Jun 14, 2019 at 4:58 PM
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    Same. Literally just held the brake mashes the gas and the both tires started spinning. Couldn’t have been easier
    Rex Kramer[QUOTED] likes this.
  30. Jun 14, 2019 at 5:04 PM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    I'm the same way but.. might light it up on the way to get a new set.
    Larmand[QUOTED] and Rex Kramer like this.
