What's This Switch for?
Discussion in '2.5 Gen Tundras (2014-2021)' started by 10forty2, Jan 4, 2017.
  1. Jan 4, 2017 at 11:42 AM
    10forty2
    10forty2 [OP] New Member
    Doug
    NC
    2017 Tundra TRD-4x4 XSP-X
    It's the one at theSwitches.jpg bottom in the middle named "LED." Looked all over the manual and searched all over the inter-web....can't seem to find it. I've toggled it on and off several times and don't see that it does anything except toggle the light in the switch itself. Anyone? Beuller? Beuller??
  2. Jan 4, 2017 at 11:45 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Mine doesn't have it. Maybe it's part of your package with the idea that you will add aftermarket light bar. Not sure.
  3. Jan 4, 2017 at 11:46 AM
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    I would have someone stand outside and walk around the truck as you turn it on and off to see if it activates something outside. Possible could of been an old switch from the previous owner for a light bar or something that got taken out. Also I think the XPS comes with illuminated door sills, might be the on/off switch?
  4. Jan 4, 2017 at 11:46 AM
    cd121082
    cd121082 New Member
    chris
    Washington State
    2016 Silver Tundra TRD OffRoad
    none yet
    What you should do is pop it off and see what other wires it has connected. More than likely its an aftermarket switch that the dealer installed. What i would also suggest is wait until its dark out and turn it on and walk around the truck to see what is on then go back in and turn it off and see what may have turned off.
    NewImprovedRon likes this.
  5. Jan 4, 2017 at 11:48 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    It came brand new with that? Looks like an aftermarket switch someone would install to use with their light bar. If you dont have a light bar and its brand new, that is odd. Maybe the dealership forgot to add it, or took it off?
    Bear likes this.
  6. Jan 4, 2017 at 11:49 AM
    BRNG ITT
    BRNG ITT New Member
    San Antonio, Texas
    2016 CrewMax TRD PRO
    Should be for the LED DRLs below your headlights that came on your XPS-X edition.
    NewImprovedRon and joonbug like this.
  7. Jan 4, 2017 at 11:51 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    That makes sense. Like this:
  8. Jan 4, 2017 at 11:56 AM
    cd121082
    cd121082 New Member
    chris
    Washington State
    none yet
    i wonder how bright those would be and if its even worth having.
  9. Jan 4, 2017 at 12:00 PM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    This
  10. Jan 4, 2017 at 12:01 PM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    I couldn't answer that for you. But based on the price for them, $340ish, I'd save and put money into a retrofit or other light bar. Personally I don't like the LED below the headlights like that.
  11. Jan 4, 2017 at 12:03 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Gulf states editions are so weird.
    boardude and Backslider like this.
  12. Jan 4, 2017 at 12:11 PM
    10forty2
    Doug
    NC
    Might be the winner. I'll check it out later. Thanks!!
  13. Jan 4, 2017 at 2:18 PM
    Bingo! Was his name-o!
  14. Jan 4, 2017 at 2:49 PM
    https://youtu.be/I2VeDF405bI
  15. Jan 4, 2017 at 3:56 PM
    Glock17
    Glock17 New Member
    Helena, Al.
    2016 TRD PRO
    Fab Four bumpers, Warn Zeon 10, Line X, Toytec lift, Rugged Tri fold cover, Cooper SST, Weathertech liners, Weathertech vent guards
  16. Jan 4, 2017 at 4:48 PM
    10forty2
    Doug
    NC
    Yep...that was it!
