What's needed to make this 305/70/18 setup work?
Discussion in 'Wheels & Tires' started by Jasbo, Apr 16, 2018.
  1. Apr 16, 2018 at 9:34 PM
    Jasbo
    Jasbo [OP] New Member
    2013 SR5 doublecab 4x4
    First time poster here! I'e lurked forever trying to gather info. I wanted to try and figure most things out on my own before asking questions. I'e read through so many post my head is still spinning but I've think I've managed to get in the ballpark. I need suggestions or conformation I'm on the right track please. I'e got a 2013 SR5 doublecab 4x4 bone stock. Im thinking toytec boss kit with uca. 18"x9" wheels +18 offset and 305/70/18 ( 34.8 ×12x18). Looking to be outside of wheel well (even or slightly outside if I install flares). I'm fine with mud flap removal and massaging the plastic but will I require any other mods to make this setup work? Any suggestions on this setup or other tire reccomendations is appreciated. Thanks in advance!
    dcsleeper408 likes this.
  2. Apr 16, 2018 at 10:55 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Will most likely need a CMC and a little more than massaging the plastics.
    Bob and dcsleeper408 like this.
  3. Apr 16, 2018 at 11:32 PM
    Old Alan
    Old Alan New Member
    San Jose
    2017 SR5 Crewmax
    Toytec Boss lift, Black Rhino Warlords wheels, 295/70/18 Nitto Ridge Grapplers, SDHQ Sliders, RBP grill, color matched surround and bulge, Kendwood head unit.
    I put 295/70/18 Ridge Grapplers on with a 12 offset. I have Joonbug's old ToyTec Boss setup. I removed all the intruding fender plastic and I can barely get a sheet of paper between the rubber and body mount. I cant imagine 305's would fit without some metal getting hacked off.
    joonbug and zcarpenter92 like this.
  4. Apr 17, 2018 at 5:08 AM
    Jasbo
    Ok. So I'm assuming my problems would lie in the overall width? The 295/70/18(34.3x11.6) plus a cmc would likely give me the clearance I'm needing? The 18x9 +18 offset looks to be giving me 5.7" of backspace which from what I read several times seems to be the minimum I should be looking for. I'm fine with downsizing a little more overall tire configuration to get a comfortable fit but if I'm going to have to drop much I may as well shuck the toytec and run a bds 5" lift. What is yall' ture size suggestions to run on this wheel setup on 3/1 lift?
  5. Apr 17, 2018 at 5:59 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    I’d say pick the brains of @T-Rex266 and @boardude since they both run 305/70R18’s.
    boardude and T-Rex266 like this.
  6. Apr 17, 2018 at 7:15 AM
    Yes, you'll still want to push your fender liner in a bit more and trim down your factory skid if you have one.
    boardude likes this.
  7. Apr 17, 2018 at 8:31 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome. The body or cab mount chop is not expensive and barely noticeable when done right. I didn't want to do mine but now that I have I've got a little piece of mind having the extra clearance.
    joonbug likes this.
  8. Apr 17, 2018 at 8:44 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    porkitt likes this.
  9. Apr 17, 2018 at 8:50 AM
    Jasbo
    I appreciate the info. I'm not dead set on that size tire after reading all that I have I just used that size tire as a base line to finetune. Would it be a better fit to go with narrower tires or would doing a cmc moving around liners and trimming skid plate ( if applicable ) allow suffecient space for the 305's?
  10. Apr 17, 2018 at 8:59 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Lots of people here successfully running 35s or 305s. I have 295 and am going to 305 to protect the wheels a little better. Even with the 295s I needed a BMC. The UCAs you choose play a part. The more caster the more you need the BMC.
    zcarpenter92 and joonbug like this.
  11. Apr 17, 2018 at 9:12 AM
    ToyotaTundraMike
    2015 Tundra
    Go down to 305/65/18 or 295/70/18 and you’ll be good!
  12. Apr 17, 2018 at 9:39 AM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Listen to thesya Guys. On point.
  13. Apr 17, 2018 at 11:29 AM
    Jasbo
    Ok so I'm looking a spc uca, I will do a cab mount chop and I'm looking at these wheels. Is the 18 offset what could hurt me?Screenshot_2018-04-17-13-30-12.jpg
  14. Apr 17, 2018 at 11:31 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    No, +18 is a good offset.
  15. Apr 27, 2018 at 4:45 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    I run that same size and offset
  16. Apr 28, 2018 at 10:46 PM
    rexxwood
    rexxwood New Member
    REXX
    The Couve Vancouver Wa
    2018 Tundra 4x4 5.7 limited CrewMax with Premium package in Cement
    From the dealer: 305/65/R18 around Black Rhino Armory 18x9.5 Gunmetal 3" lift Linex amp research power steps My pocket: Thinkware F800 PRO front and rear dash cams with Cellink battery matched rear front window tint with visor
    whats the difference in the width on 295/70 vs 305/65?
    thanks
  17. Apr 28, 2018 at 10:53 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    11.6” vs 12”. But depends on the brand. Some are off by a few tenths.
  18. Mar 12, 2023 at 9:19 PM
    Luke_Skywalker
    Luke_Skywalker New Member
    Luke
    2020 Tundra TRD Pro
    Eibach TRD Pro Front Springs, Dirt King UCA's Coachbuilder +3 shackle (poly bushings)/carrier bearing drop, steering upgrade, bumper shims, White Knuckle Sliders, Leitner Designs, Baja Designs, Switch Pro, Victron Solar, BORA 1.25", BFG KO2s, Wheelers Superbumps, VLED interior lights, 12" Sub, Window Tint.
    Did you end up going to those 305s? Im trying to decide on which tire size to go to. I want the tallest I can get without a 37" 305/70/18 seems to be it. BMC and all that is done so not worried about rubbing anywhere.
    831Tun[QUOTED] likes this.
  19. Mar 13, 2023 at 10:13 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    No, I ended up on 37s
  20. Mar 13, 2023 at 10:26 AM
    D4x4TRD
    D4x4TRD New Member
    Định
    Va beach, VA
    2012 Sr5 DC TRD 4x4 Blaaaaaack baby 4.6liter
    Blacked out front grill badge Bigger tires 305/60r18 Tonneau cover
    I have 305/60r18 factory rims. Around a 2.5” lift. 2012 dc. I didn’t have to trim anything. The tire has about a 1/4” gap from the upper control arms. No rubbing at all.
    Luckster likes this.
