What's my 2004 SR5 4x4's gear ratio?
Discussion in '1st Gen Tundras (2000-2006)' started by Eglise0, Apr 12, 2025.
  1. Apr 12, 2025 at 8:16 AM
    Eglise0
    Eglise0 [OP] New Member
    Toyota Tundra 2004
    none
    I recently purchased a 2004 tundra SR5 4x4 6 cylinder, I believe the rearend is toast and I’m trying to figure out what the gear ratio is, no tow package, auto. This is what’s on the door sticker.
    VCK40l
    C/TR 056/FB12
    A/TM A05A/A340F
    #531
    Any ideas I keep getting different answers when I try to look it up.
    Thanks for any help.
  2. Apr 12, 2025 at 8:17 AM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    it should be a 4.30
  3. Apr 12, 2025 at 11:21 AM
    Eglise0
    Toyota Tundra 2004
    none
    I’ve seen that in a few places but then I also see where it was only trucks with the tow package that had the 4.30. I don’t think it had the tow package it just has an overdrive button on the end of the shifter.
  4. Apr 12, 2025 at 2:48 PM
    This is how to decode the sticker below the driver door latch (on the physical door) which gives your drivetrain specs: https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-2250#post-3818756
    The problem is, trying to find any legitimate source of info on the Tundra axle decoding from '00-'04 and '05-'06 has been elusive for me, so I can't tell you what A05A is, exactly. I can tell you, with certainty, that info you'll find on Tacoma, and on various spec sheets around the internet, didn't add up math-wise for my truck.
    That said ...
    This is the list @whodatschrome pulled together, though I'm not sure the original source.
    2000-2003
    3.91 - V8, 4x4, auto trans
    3.92 - V8, 4x2, auto trans
    4.08 - V6, 4x2, auto trans or manual trans
    4.10 - V6, 4x4, manual trans
    4.30 - V6, 4x4, auto trans
    2004, Regular Cab or Access Cab
    2004, Double Cab
    4.08 - V8, 4x2, auto trans
    4.10 - V8, 4x4, auto trans
    2005-2006
    3.77 - V6, 4x2, auto trans
    4.08 - V6, 4x2, manual trans
    Dook55 and whodatschrome like this.
  5. Apr 12, 2025 at 4:50 PM
    Eglise0
    Toyota Tundra 2004
    none
    It does look like it should be the 4.30 ratio, I’m going to yank it out I’m sure it will have some numbers or I can count teeth or something.
    Thank you
  6. Apr 12, 2025 at 4:54 PM
    whodatschrome
    lots of dents
    Here’s a sure fire way to figure it out. I literally copied the first video that i google searched. Perhaps there’s better videos, but this will explain how to determine the ratio.
    https://m.youtube.com/watch?v=6rhOnY7yNRA
  7. Apr 12, 2025 at 4:58 PM
    whodatschrome
    lots of dents
    If it turns out you need new gears, due yourself a favor and install a lower gear set in both the front and rear. Even if you still have the small stock sized 245/70-16 tires. Your truck will thank you by rewarding you with better fuel economy, longer transmission life, regaining lost HP, better acceleration, more useable cruise control.
    shifty` and Dook55 like this.
  8. Apr 12, 2025 at 6:15 PM
    Eglise0
    Toyota Tundra 2004
    none
    Thanks for the feedback I’m starting to get a picture here.
