What zerk fitting is this?
Discussion in '1st Gen Tundras (2000-2006)' started by saltyreefer, Jul 13, 2019.
  1. Jul 13, 2019 at 8:42 AM
    saltyreefer
    saltyreefer [OP] New Member
    It’s on my universal joints.
  2. Jul 13, 2019 at 8:49 AM
    saltyreefer
    Also, how much grease should be pumped in them. I grease electrical motor bearings at work but not sure about these.
  3. Jul 13, 2019 at 9:01 AM
    gdisarray
    gdisarray Short term member
    2023 Tundra Limited HV
    Tint and wheels. Decked box in the bed. S and B Cold Air filters under the hood. Shiftpower throttle response controller.
    It's it just me? I don't see a zerk fitting
    02goes and Filthyphil like this.
  4. Jul 13, 2019 at 9:05 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    bmf4069 likes this.
  5. Jul 13, 2019 at 9:06 AM
    Kn4x2
    Kn4x2 Common sense is not so common!
    3rd rock from the sun
    2010 DC 2WD
    Afe Pro Dry filter Tinted windows Coverking seat covers Traxion tailgate ladder Auto vox M1 backup camera
    I don’t see one either.
  6. Jul 13, 2019 at 9:09 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    This guy
  7. Jul 13, 2019 at 9:10 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    X3
    The brass colored area doesn't look like a zerk.
  8. Jul 13, 2019 at 9:13 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    First. That is what Toyota refers "Double carden joint." I just always refer to them as a "U joint." I also can't tell if it's a true zerk fitting. I understand that starting in 2018 Mama Toyota no longer has factory zerks on the driveline.
    On any driveline U joint you want to pump grease until you hear it "popping" as it comes out around the seal. So you need a quiet atmosphere. And wipe off the excess. That shit will fling and make a mess.
  9. Jul 13, 2019 at 9:18 AM
    EK20
    EK20 New Member
    Yeah, those are called "flush type" grease fittings. A mess to lubricate them with the needle adapter and most of the time they are included in aftermarket parts. Designed for areas where clearance is an issue. I rarely see them used where this would apply so I tend to think part manufacturers are just being cheap.
  10. Jul 13, 2019 at 9:22 AM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
  11. Jul 13, 2019 at 9:38 AM
    saltyreefer
    Great info! Thanks!
    I had them replaced last year and was not happy to see these as I had no idea they existed and looking at them I knew they would be a PIA...
  12. Jul 13, 2019 at 9:44 AM
    saltyreefer
    What grease are you guys using? I have red sticky (forgot the name) in my gun that I used in my boat trailer bearings. Should I use that?
  13. Jul 13, 2019 at 9:48 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Anyone know if they're threaded in where they can be exchanged? Or, pressed in for the life of the u-joint?
  14. Jul 13, 2019 at 10:16 AM
    Professional Hand Model
    Hand Protectors
    Use whatever the spec on the new joint states. The OEM takes Moly-B.
    ‘B’ is for Butter.
  15. Jul 13, 2019 at 10:05 PM
    02goes
    02goes New Member
    2002 Tundra Limited 4X4
    Regular grease is what shops use on 18 wheelers, so if normal grease can do the job on these heavy duty trks just use what you want. That red grease, by the way, is heard to be sworn by as the go to grease, so I bought a tube. Lol, I have racing grease and all kinds laying around, but this thick sticky stuff should do very very good for the boat trailer bearings that get submerged in salt water.
    If your concerned about what lube to use, don't. Just hit all the zerks every oil change or after every water submersion in between. You can never overdo greasing the bearings.
    I've never seen a zerk or grease point on a universal joints bearing cap or caps. You can always get the grease gun on a universal joints zerk when rotating the shaft until it's exposes it's widest point where the fitting is at.
    https://www.walmart.com/ip/Lucas-Oi...MI-e3clNCz4wIVD_DACh0BhAkfEAQYBSABEgLtDfD_BwE
    15whtrd likes this.
  16. Jul 14, 2019 at 9:14 AM
    bajaphile
    bajaphile New Member
    Solana Beach, Ca
    2001 4x4 Limited
    Icon Coilovers, Icon AALs, JBA headers, 285/75r16 BFG KO2s
    I had a double cardan shaft made locally for my Land Cruiser and I asked the shop what type of grease they recommend. He said anything Lithium based with moly is their preference.... so pretty much any moly grease you get will be fine. The FSM I believe states non moly. There are all sorts of discussions about Moly vs non, and generally anything with moly added exceeds the requirements for the non moly... In closing, I just stock moly grease for everything rather than different guns with different stuff. Been using the Red Line stuff... its expensive though.
  17. Jul 14, 2019 at 9:36 AM
    Hand Protectors
    The Moly also has an added benefit that if it ever dries out, it is still slippery like dry graphite. Its also highly impervious to water compared to other greases. Also, its a great electrical conductor.
