What would you do? Need advice
Discussion in '3rd Gen Tundras (2022+)' started by PJ-Air-Fire, Dec 22, 2024.
  1. Dec 22, 2024 at 6:21 AM
    PJ-Air-Fire
    PJ-Air-Fire [OP] New Member
    So I will be purchasing a 3rd gen after the new year and looking to get an SR, SR5, or limited. My thought is to use the extra money (5-10k) not purchasing a higher end model and putting that money into the suspension and wheels. I do a lot of hunting where I’m on dirt roads and 2 tracks. I will be looking to put 35’s on. This will also be my daily driver.
    So I’m asking all of you for advice based off of experience with knowledge of aftermarket products what would you do if you were in my shoes?
  2. Dec 22, 2024 at 6:24 AM
    SoCal_Erik
    SoCal_Erik New Member
    2023 SR5 Sport 4x4, 2016 4Runner
    Buy the truck that will meet your needs for now, that way you aren’t in a rush to upgrade anything quickly and you can take your time figuring out what you like.
  3. Dec 22, 2024 at 6:40 AM
    buzzkill42
    buzzkill42 New Member
    Joe
    2024 Tundra 4x4
    To me, there are two buckets for options/accessories/mods - those that are better from the factory and those that are better (or have more options) aftermarket.
    A couple examples - in my opinion, heated seats fall in the first category with rims/tires in the second.
    Similar to what @SoCal_Erik said, I'd suggest buying what checks the most boxes for you right now and modifying what isn't available from Toyota or has better options aftermarket.
    Good luck!
    MAC25Tundra likes this.
  4. Dec 22, 2024 at 6:42 AM
    Jernik
    Jernik New Member
    Jeremy
    2020 MGM Tundra Crewmax
    All I can say is to make sure you get the trim level that has all of the features/comforts you want. Adding lift and tires to any truck is easy. Adding higher trim features to a lower trim model is often more difficult (depending what it is).
  5. Dec 22, 2024 at 8:59 AM
    PJ-Air-Fire
    Thanks for replying fellas. I’m not into all the bells and whistles of the higher trim
    models and don’t plan on upgrading interior trim features. Comfort is nice however I’m not concerned about heated interior components.
    So I’ve seen Fox, Icon, Westcott and a few other kits and shocks. So that’s what I’m asking is pros and cons. The manufacturers all claim to have the best products. I want to hear from non affiliated folks who invested in these products and liked or disliked for whatever reason.
    Thanks
    ramnj and MooseLang like this.
  6. Dec 22, 2024 at 9:27 AM
    Tundra family
    Tundra family New Member
    Camburg is top tier, icon is next level as well. Fox is hype.
    Just sayin.
  7. Dec 22, 2024 at 9:28 AM
    Breathing Borla
    Northern Illinois
    in your case I would try to find one that has the TRD lift on it already, then you can just add tires if you want
  8. Dec 22, 2024 at 11:15 AM
    Siblue
    Siblue Old member
    Ryan
    25 Tundra TRD pro
    Fox is top tier.
    WD and icon are hype.
    Subjectively speaking
    shellshock likes this.
  9. Dec 22, 2024 at 11:24 AM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    Just about every after market suspension will be better. Even better than the TRD Pro suspension. My SR5 premium 4x4 didn’t come with skid plates. So I got a Victory 4x4 aluminum skid.
  10. Dec 22, 2024 at 12:38 PM
    PJ-Air-Fire
    This is what I’m talking about. Keep it coming
  11. Dec 22, 2024 at 12:42 PM
    LionsFan20
    LionsFan20 New Member
    Josh
    24 Tundra
    Just putting it out there. But all the bells and whistles are VERY cool, when they break they are often VERY expensive to repair lol. Like that power up and down tailgate….probably not cheap to fix
  12. Dec 22, 2024 at 1:40 PM
    Rockpig
    Rockpig You did what?
    08 Limited
    Keep in mind that adding an aftermarket lift comes with a fairly hefty price and the ability for Toyota to deny warranty claims if something goes wrong down the line. They'd have to prove that the mod caused the damage but at this point I wouldn't trust that Toyota wouldn't say your engine blew because of larger tires.
    I'd be looking at the cost that a lift, install, wheels and tires are going to add to the overall purchase price. Also that is funds that will come straight out of your pocket as apposed to buying a more capable trim level that you can finance over time. Not sure what the trim levels you're looking at come with but I'd at least consider something with the terrain control and a locker if you're doing any off roading. Mud and snow will slow any 4WD down, having the locker can make the difference in getting home or spending the night.
    mrlittlejohn and MEGA VOL like this.
  13. Dec 22, 2024 at 2:14 PM
    Bnewman077
    Bnewman077 Happy 2023 Owner
    2023 Tundra TRD OR Lunar Rock
    18” Method Wheels, 35x12.5 Toyo AT3, TRD Pro suspension with Westcott preload lift and Icon rear springs
    If you’re talking about mostly maintained dirt roads then TRD Off-Road suspension is more than enough. I have a Limited OR and love it. Originally did a 2” BDS level and had no issue fitting 35x12.5s. Since then I upgraded to TRD Pro takeoffs with Westport 3/1. Ride is better with the pro setup and a little more fun off road at higher speeds.
    TRD OR with a level is going to be the most economical to fit 35s and have fun off-road getting where you need to go.
    here is mine with the original TRD OR + Level
    emerson and SoCal_Erik like this.
  14. Dec 22, 2024 at 2:56 PM
    Markus
    Markus Hermitic Member
    Mark
    Boring, MO
    2 1794 Tundys 2014 and 2023 AG TRD
    A few
    IDK, that heater steering wheel is kind of fire
    ramnj, SWB Tundra, Hoody and 4 others like this.
  15. Dec 22, 2024 at 4:28 PM
    Zebjones24!
    Zebjones24! New Member
    2024 Red Tundra trd
    I put Fox 2.0 level coil overs on my truck. 2” lift in the front and put 1” cornfed lift in the back. All I can say is Fox is the real deal and they suck up bumps like nothing I’ve ever had. Definitely not just hype!
    MAC25Tundra and Tundrastruck91 like this.
  16. Dec 22, 2024 at 4:35 PM
    SM Tundra
    SM Tundra New Member
    Cody
    2024 Limited Smoked Mesquite Tundra
    Ever since I added 34s and 17” wheels to my limited the ride was drastically improved from the stock tires. But I will say it’s been cold lately and the heated steering wheel has been so nice. Also the limited has AC seats, which is nice in the summer. As others have said the factory 3” lift will allow for 35s and is warrantied which is nice. So if you wanted a truck ready to go off the lot that might be your best bet. I had a trd pro Tacoma before my tundra and the fox shocks were nice on any terrain.
  17. Dec 22, 2024 at 6:03 PM
    Hella Krusty
    Hella Krusty New Member
    Your tailgate goes power up?
  18. Dec 22, 2024 at 6:19 PM
    Markus
    Mark
    Boring, MO
    A few
    New for 25
  19. Dec 22, 2024 at 6:26 PM
    Hella Krusty
    Time to upgrade…..
    Markus[QUOTED] likes this.
  20. Dec 22, 2024 at 6:39 PM
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra
    None
    Add in some massaging seats while you’re at it. :)
  21. Dec 22, 2024 at 6:42 PM
    Frank_TRD23
    Frank_TRD23 New Member
    2023 Tundra TRD Mag grey
    1.5 Wescott lift 20" wheels on 37s Stillen Trucontroller
    If you do hunting. Maybe stay away from the nicer interior. You can always pay cash on upgraded leather seat skins.
    vtl likes this.
  22. Dec 22, 2024 at 7:03 PM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    Cat cover
  23. Dec 22, 2024 at 7:16 PM
    mrlittlejohn
    mrlittlejohn New Member
    Michael
    2022 Toyota Tundra Limited
    I personally would not recommend the SR. That is a work level truck and de-tuned. Less HP doesn't mean better fuel economy either. You may not be into the bells and whistles as you say, but as mentioned before and maybe in some other words... Don't put yourself into a position saying 2-5 years into owning the truck, "I wish I would have got this or that option!"
    Food for thought,
    BlackNBlu likes this.
  24. Dec 22, 2024 at 7:26 PM
    bailey bulldog
    bailey bulldog New Member
    And a small gas tank.
  25. Dec 23, 2024 at 4:35 AM
    Brian89
    Brian89 New Member
    Not sure what part of the country you are in but look at the price paid threads and compare regions when buying. Some regions like Gulf States(Tx, Ok, La, Ar, Ms) and Southeast Toyota(Fl, GA, AL, NC, SC) have a huge amount of junk add ons that inflate the MSRP. Its worth a plane ticket to get a better deal. I saved 10k flying to Kansas and had no add ons. I much prefer to pick what I put on my truck over what the dealership gets the best margin on.
    Garand, BlackNBlu and mrlittlejohn like this.
  26. Dec 23, 2024 at 7:26 AM
    SWFL23TRDOR
    SWFL23TRDOR New Member
    LOGAN
    fort myers
    BLACK 23 OFF ROAD 2023
    I'd check out the bilstein 5100's if i were you. alot of guys had good luck with them on the previous gen.
  27. Dec 23, 2024 at 7:56 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    As stated above, skip the SR. SR5 or Limited for increasing option levels.
    Bells and whistles are nice, but I agree, not absolutely necessary.
    As I've gotten older, comfort has become a bigger factor. In a cold climate, heated seats and steering wheel are really nice.
    It sounds like you're honest with yourself about what you NEED for off-road capabilities. It doesn't take much to fit 35's on a gen3 Tundra.
    The top-line aftermarket suspension gear (Camburg, Fox, etc.) while great, are pricey and overkill for most.
    The TRD Offroad package is one of those, nice to have, but likely rarely needed or used things, unless you are off-road way more than on.
    The suspension isn't all that different from the 4X4 without it. The biggest thing (IMO) is the locking diff, but Toyota has that only usable in 4-LO, which is dumb.
    Bilstein 5100's or RC 2" lift struts and maybe a 1" spacer in the rear and you'd be set for 35's.
    To go the factory route:
    You can't go wrong with the 3" TRD lift. Factory installed and no warranty concerns.
    MEGA VOL likes this.
  28. Dec 23, 2024 at 8:12 AM
    Fobroader
    Fobroader New Member
    Alberta
    2020 Platinum
    I always buy the vehicle with the most options. Adding wheels, lift and such is easy, adding heated steering wheels, tires, better upholstery is not easy or cheap.
    Kerplunk and 75tranzam like this.
  29. Dec 23, 2024 at 8:20 AM
    Frank_TRD23
    If you have the cash, better option for add ons than to finance those add ons .
  30. Dec 23, 2024 at 9:35 AM
    Eznk1
    Eznk1 New Member
    Tony
    2024 Tundra
    This is a viable option. I went to KY to get mine without all the extra stuff I didn’t want.
