What tool do I need to remove this pin? Where do I buy it (store)?
Discussion in 'Sports, Hobbies & Interests' started by Sunnier, Jun 15, 2018.
  1. Jun 15, 2018 at 10:44 PM
    Sunnier
    Sunnier [OP] Pity the warrior that slays all his foes
    Sunny
    San Diego, CA
    I need to remove the doors from a huge, made in Mexico armoire so I can move it through a doorway. Looks like the metal pins that hold the hinges will just pop out the top if I can tap them from the bottom.
    Can you suggest a tool that does this, and tell me what it's called so I can ask for it at the store? I have an awl but the tip is pointed. I can picture a leather punch being about right. But... is there any tool meant to do this, that I could grab at Home Depot or Lowe's on Saturday?
    The pin is slightly less than 1 cm across.
    Any suggestions appreciated. I've had to give up for the night,but will try again tomorrow.
    ColoradoTJ likes this.
  2. Jun 15, 2018 at 10:52 PM
    Porschetech29
    Porschetech29 New Member
    Francis
    Rancho Cucamonga, CA
    2008 white double cab 4x4
    Hammer and punch set
  3. Jun 15, 2018 at 10:58 PM
    Sunnier
    Sunny
    San Diego, CA
    Okay. I have a hammer. So I'll look for a punch set.
    831Tun likes this.
  4. Jun 15, 2018 at 11:07 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Punch or nail set. I've used a nail too in the past but obviously they bend easily. You can also use a hinge pin from another door.
    Sunnier[QUOTED][OP] likes this.
  5. Jun 15, 2018 at 11:14 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    A little WD-40 wouldn't hurt either.
  6. Jun 16, 2018 at 5:12 AM
    aRabidLunatic
    aRabidLunatic Professional Hobo
    Central Texas
    2015 Tundra SR5 Black
    Hit it with a small screwdriver and hammer from underneath.
    Sunnier[OP] and Pudge like this.
  7. Jun 16, 2018 at 6:27 AM
    Outbound
    Aaron
    Northern Alberta
  8. Jun 16, 2018 at 7:32 AM
  9. Jun 16, 2018 at 7:34 AM
  10. Jun 16, 2018 at 8:02 AM
    You can also use a flat head as a punch to get it out.
    Pudge and aRabidLunatic like this.
  11. Jun 16, 2018 at 10:24 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    You'll definitely want some kind of lube on there...
  12. Jun 16, 2018 at 10:33 AM
    Baja Mike
    South Bay, Ca.
  13. Jun 16, 2018 at 11:43 AM
    Professional Hand Model
    Hand Protectors
    Spray some plastidip on it. Just kidding. Like the others said use a punch or nail set. Line it up from underneath and tap it with your hammer. Then grab the head with some pliers and wiggle it out from above. Do your bottom hinges first. Then grab or have someone hold the door when you do the top hinge to keep it from getting/doing damage in a fall. Reverse order when installing back together.
    Sunnier[OP] likes this.
  14. Jun 16, 2018 at 11:45 AM
  15. Jun 16, 2018 at 1:03 PM
    Sunnier
    Sunny
    San Diego, CA
    Tried but it didn't work, which is why I posted for help. Thanks though!
    This is what I wanted to do to the damn thing:
    But I worried about setting the house on fire. Then I thought of:
    Instead I bought the set @Baja Mike recommended.
    I didnt know which would be best to do first. Thank you for being specific!
    Gotta get back into painting. I'll report back later when the hinge pin removal is complete....
  16. Jun 16, 2018 at 1:04 PM
    That's real nice! Love that natural color of it
  17. Jun 16, 2018 at 1:09 PM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    More fun with something like this. :D
    4x4_Angel and T-Rex266 like this.
  18. Jun 16, 2018 at 6:15 PM
    Sunnier
    Sunny
    San Diego, CA
    Yeah. It's a nightmare. We removed the door between the bedroom and hallway; not enough width to clear. We'd already removed the decorative trim at the top sides of the armoire (because we remembered doing that to get it in the room), but no matter what we do, it's not fitting (but probably will when we remove the front doors). No renovation on the bedroom doorframe, so we're thinking the front doors of the armoire have bowed out slightly. If I look closely, I think I see that, but mainly I "know" it because we got it in through the same doorway about 10 years ago. So, logic demands that we can get it back out. Somehow....
    Okay <deep breath> headed back to the mines....
    4x4_Angel and SouthBoundSteve like this.
  19. Jun 16, 2018 at 10:12 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Have you made it fit through the door yet?
  20. Jun 16, 2018 at 11:31 PM
    Sunnier
    Sunny
    San Diego, CA
    No, not yet. Got the punch set today while on a paint supplies run to HD. Spent today doing final tape prep and first coat of paint in 3 rooms, including mentoring my son while he did first coat (I did edges and high up, but he did the wall from his shoulder to the floor, all around). He was into it, far above just not complaining, so we were pleased. Tomorrow while he sleeps in, I'll do final coat on these 3 plus the hallway. When he gets up (tonight we're all "camping" on mattresses w/o frames in the MBR), we'll swap attention back to the armoire. I'm trying not to stress about not being able to get it out before the carpet installation Monday (logic: we got it in; we can get it out).
    gosolo[QUOTED] and 4x4_Angel like this.
  21. Jun 17, 2018 at 12:52 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    Hope you get it figured out, lady! That's crazy! Definitely if you got it in you should get it out!
  22. Jun 17, 2018 at 6:03 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Most flooring contractors have a clause in their contract excluding moving furniture. This being said, most installers will work with you, especially if you and a helper are standing by to move the items back and forth as required to install the padding and then the carpet.
    Not a preferred route, but perhaps an option.
    Additional note: the installer is never the salesman and in fact is frequently a 3rd tier subcontractor.
    Sunnier[OP], driverdog and 4x4_Angel like this.
  23. Jun 17, 2018 at 6:30 AM
    Hand Protectors
    Back in the day when someone cut a 2x4 too short I’d send them to get the stud stretcher out of the trailer. That would keep them busy for a few. In your case, you may have to remove all your casing work down to the framed opening. Or at the minimum remove the stop casing which will give you 1/2” off each side for a total 1” (hoping its not a split jamb door).
    Am I missing something that you can’t remove the hinges from the furniture? Put some oil or rust blaster on the hinge and soften it up, and tap the hinge out. Getter’dun!
  24. Jun 17, 2018 at 6:38 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    When I was an apprentice I loved being sent for a lumber stretcher, bucket of steam or box of toe nails. I would find some peaceful spot and take a nap, like in the trailer of concrete blankets. I never got in trouble, just the smart journeyman that sent me on the errand!
