what to do while engine is removed 2015 5.7
Discussion in '2.5 Gen Tundras (2014-2021)' started by twp2025, Mar 8, 2025.
  1. Mar 8, 2025 at 10:44 AM
    twp2025
    twp2025 [OP] New Member
  2. Mar 8, 2025 at 11:13 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Why is engine removed? How many miles?
    You usually don't want to fix something that's not broken yet.
  3. Mar 8, 2025 at 11:19 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    I would suggest a new starter if it comes out with the engine. They are a booger to replace or like $2 and up to get done.
    The Alternator as well, not as spendy but not easily replaced.
    HulkSmurf14 likes this.
  4. Mar 8, 2025 at 11:26 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    New vacuum hoses and radiator hoses if you can, look under the IM for mouse droppings and blow and clean under there out, and PCV, replace that buffer while you're at it!
  5. Mar 8, 2025 at 11:38 AM
    twp2025
    128000 miles
  6. Mar 8, 2025 at 11:39 AM
    twp2025
    yes, starter and alternator are 2 things that I left off my list, ty
  7. Mar 8, 2025 at 11:40 AM
    IEsurfer
    IEsurfer New Member
    jimbo
    Socal
    2005 tundra 4x4
    Reseal cam towers on both sides and timing chain cover
  8. Mar 8, 2025 at 11:47 AM
    twp2025
    Is this something that comes with a remanufactured engine?
  9. Mar 8, 2025 at 11:49 AM
    IEsurfer
    IEsurfer New Member
    jimbo
    Socal
    2005 tundra 4x4
    No if you have black fipg sealent where the cam towers are then they replaced it if you don’t see black sealent then it hasn’t been touched
  10. Mar 8, 2025 at 12:18 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    If you’re doing the starter and alternator only use Toyota parts. You will pay a bit more but they will last unlike the aftermarket.
  11. Mar 8, 2025 at 12:54 PM
    twp2025
    Absolutely, I practice the same with my Hondas.
    Ruggybuggy likes this.
  12. Mar 8, 2025 at 1:02 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Replace seal on transmission input shaft.
  13. Mar 8, 2025 at 1:02 PM
    BeauDacious
    BeauDacious 040 > all other colors
    Beau
    14 DC 4x
    Completely clean and degrease the engine bay.
  14. Mar 8, 2025 at 1:11 PM
    CasperTheFriendlyTundra
    CasperTheFriendlyTundra New Member
    Clean, sand, and paint the frame and front suspension.
    I'd also replace every hose that I could afford to replace.
