What to buy with supercharger?
Discussion in 'Performance and Tuning' started by Fireman/68W, Apr 10, 2019.
  1. Apr 10, 2019 at 9:36 AM
    Fireman/68W
    Fireman/68W [OP] New Member
    J
    S/E Wyoming
    2018 White SR5 Tundra
    A lot in progress!
    I have noticed that people are buying odds and ends to ensure better performance out of their supercharger and ensure they are also not destroying the motor.
    Like oil reservoir canister better belts etc. Any body have a list of suggestions of recommend upgrades when adding the supercharger?
  2. Apr 11, 2019 at 3:29 PM
    frogger
    frogger just boost it
    Stephen
    Louisville Ky
    2008 S/C Tim Mica SR5 5.7L DC 4X4
    too much to list
  3. Apr 11, 2019 at 3:53 PM
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    According to Magnuson, nothing else needed outside of their kit. I am changing my plugs every 30k which is sooner than stock.
    Fireman/68W[OP] likes this.
  4. Apr 11, 2019 at 3:54 PM
    madmatt
    madmatt New Member
    Ocala Florida
    2018 Crewmax 4x4. TRD
    A lawyer for the speeding tickets?
    Midway, Darkness, G10dra and 3 others like this.
  5. Apr 11, 2019 at 3:55 PM
    Get out of jail free...cards.
    Patriot and Fireman/68W[OP] like this.
  6. Apr 11, 2019 at 3:55 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    An extended warranty..
  7. Apr 11, 2019 at 3:56 PM
    I've seen a few guys here use the oil canisters but forgot what they are actually called
  8. Apr 11, 2019 at 3:57 PM
    Dontra
    Dontra Newer
    Don
    AR
    2021 Ram Big Horn
    2021 Ram Patriot Blue, Lonestar or Bighorn, Crew cab 4x2, 5.7 bed, 5.7 Hemi etorque, Level 2, anti-spin 321 rear end, Air ride, 33 gal tank, 18 in wheels, Multifunction tailgate, Ram box, Wheel liners, MT Brown Deluxe bucket seats, 8.4 no navigation, Trailer brake controller. Front and rear rubber mats. Mopar power steps,8 yr 85K extended Mopar warranty.
  9. Apr 11, 2019 at 4:05 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    awq735 and Black Wolf like this.
  10. Apr 11, 2019 at 4:10 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    2X^^^
    With additional positive crankcase pressure (boost) there will be more shit circulated out of the motor and back into the intake via the pcv valve. A catch can will clean that junk out of the reintroduced air and maintain a clean burn. Very important when SC'd. Not necessary according to Magnuson, but neither is a condom... Why risk it? Get the cleanest most consistent air/fuel mix and your SC will last as long as the truck.
    And I second this too.
    I also use a TRD oil filter and change the oil every 5k. I will be keeping my truck for many many years so it it all worth investing in preventative maintenance and anything that will give the SC'd motor a long, trouble free life.
    andy9743 and Fireman/68W[OP] like this.
  11. Apr 11, 2019 at 4:13 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    You can always get someone to fine tune it. And add on a monitoring system to make sure your A/F stays in check throughout the powerband.
    Depending on what you want. Methanol kits always help with gains but definitely need to be fine tuned.
    Intake/headers/exhaust always helps out.
    Catch cans are always good to have to keep from getting any blowback
    URD offers a slightly smaller pulley vs. stock size(not sure magnussen offers) they claim a 2psi boost on top.
    https://www.urdusa.com/supercharger-pulley-for-trd-3ur-fe-5-7l-supercharger-system/
  12. Apr 11, 2019 at 4:18 PM
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
    extra fuel cans, spare gas cards and road side assistance just in case and for good measure dont forget to start a thread on fuel economy after the first fill up. :rofl:
    Midway and Fireman/68W[OP] like this.
  13. Apr 11, 2019 at 6:09 PM
    frogger
    Stephen
    Louisville Ky
    too much to list
    i wish i could get mine to run right..as of latley its been throwing a po172 and 175 system to rich and it bucks and surges like mad
  14. Apr 11, 2019 at 6:12 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    You check your spark plugs?
  15. Apr 11, 2019 at 6:15 PM
    frogger
    Stephen
    Louisville Ky
    too much to list
    yup changed them and all 8 coil packs and maf
  16. Apr 11, 2019 at 6:17 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    What spark plugs you using?
  17. Apr 19, 2019 at 3:27 PM
    frogger
    Stephen
    Louisville Ky
    too much to list
    denso iridium power
  18. May 7, 2019 at 10:40 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    I change plugs every 30K as well...nothing else special or different required.
  19. May 7, 2019 at 11:30 AM
    dumbassdave
    dumbassdave Member
    Dave
    2016 Crewmax Limited
    Fireman/68W[OP] and conlons26 like this.
  20. May 7, 2019 at 11:35 AM
    G10dra
    G10dra Not a New Member
    Know that once you super charged your truck you’re switching to premium gas .
    Fireman/68W[OP] and Toyotoholic like this.
  21. May 7, 2019 at 12:28 PM
    Hobbesdsm
    Hobbesdsm New Member
    Eddie
    2016 crewmax limited
    TRD exhaust and rear sway bar, 2018 led headlights
    Check if you have a vacuum/boost leak somewhere.
  22. May 7, 2019 at 2:39 PM
    AZTundra
    Paul
    Phoenix, AZ
    I'd swap the Magnuson coolant tank for the Figs Engineering one to get a little extra bling under the hood. Maybe the aluminum radiator as well. :yes:
    Otherwise I believe the kit itself doesn't require anything extra.
    [​IMG][​IMG]
  23. May 7, 2019 at 2:40 PM
    AZTundra
    Paul
    Phoenix, AZ
    Probably add some gauges too (A/F and Boost) to monitor things.
  24. May 7, 2019 at 2:48 PM
    LEKS
    LEKS Truck name “Sancha”
    Makaha
    2013 Rockwarrior Supercharged
    A/F gauge
    Koyorad radiator
    Oil catch can
    Gatorback belt
    Dap Tune
    4:88 gears + Auburn Lsd
    Midway, VTYOTA and AZTundra like this.
