What tire pressure are you running on your E1 load range tires?
Discussion in '3rd Gen Tundras (2022+)' started by brucega7x, May 31, 2022.
  1. May 31, 2022 at 5:40 PM
    brucega7x
    brucega7x [OP] New Member
    2022 Tundra SR5 CrewMax 4X4
    I see max PSI is 80 and I assume that's probably best for fuel economy, but do you guys run them that high? Sounds like one hell of a stiff ride?
  2. May 31, 2022 at 7:10 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I only run the max PSI as stated on the tire on my trailer tires. My truck came with D rated BFGs and door sticker states 46 which is about right. I had very even wear when I replaced at 70k. I now have same tires in E rated and run at 50. 80 PSI will definitely be rough. Max PSI is just that.
  3. May 31, 2022 at 7:53 PM
    brucega7x
    t
    Thanks, this will be my first set of E rated tires so don’t really know what an appropriate pressure is.
  4. Jun 1, 2022 at 2:12 AM
    redneck47441
    redneck47441 New Member
    2018 Tundra
    Bruce apply some sidwalk chalk to a section of the tread and you can see where the chalk wears to tell if you have too much or too little pressure. I suggest around 40 psi for E tires. They are stiffer so will ride rougher in my experience.
  5. Jun 1, 2022 at 3:50 AM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    80...Holy schnikeys. I don't have a '22, but on my Tundra am running 40-42 on E rated tires. I will run 70 psi on the diesel (E rated), but that thing is a heavy biatch compared to the Tundra
  6. Jun 1, 2022 at 5:56 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    This is an excellent tool for getting air pressure correct when moving to a different tire size or load rating.
    Sundog likes this.
  7. Jun 1, 2022 at 7:14 AM
    Sean492
    Sean492 New Member
    Winston Salem, NC
    2018 MGM Tundra Sport
    I am running at 50 PSI. When I had them rotated and balanced they dropped me to around 40 and I lost a bit of MPG. I haven't come close to running at 80 however 50 seems to be a sweet spot.
  8. Jun 1, 2022 at 7:57 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'm pretty close to where I need to be. I have aftermarket bumpers, a truck box full of gear, etc so I think my 35 psi is about right. I'm always looking at tread wear for irregularities
  9. Jun 1, 2022 at 1:49 PM
    brucega7x
    Thanks I may have to give this a try!
  10. Jun 1, 2022 at 1:55 PM
    frichco228
    bigjuice likes this.
