What tire cleaner works?
Discussion in 'Wheels & Tires' started by Stocky Balboa, Nov 25, 2019.
  1. Nov 25, 2019 at 11:10 AM
    Stocky Balboa
    Stocky Balboa [OP] New Member
    OC , CA
    2018 Limited TRD 4x4 CM - Cement
    Minor stuff- Tint, rear sway bar , pedal commander, TRD drop in filter DD Exhaust, Bilstein 6112/5160, stealth 32” lightbar, Cali Raised Offroad fog light replacements.
    What are you guys using to clean your tires? (not the rim)
    Looking to remove old tire shine and desert powder dirt.
    Thanks
  2. Nov 25, 2019 at 11:16 AM
  3. Nov 25, 2019 at 11:17 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Shine supply wise guy!
  4. Nov 25, 2019 at 11:19 AM
    TheBeast The Beach
    I use Black Magic Bleche-Wite Tire Cleaner and it works pretty good on the tire to remove dirt, grime, oil and old tire shine.
    I tried the Chemical Guys stuff and it did not work much for the tire only.
    Stocky Balboa[OP] likes this.
  5. Nov 25, 2019 at 11:20 AM
    Civiceg94
    Civiceg94 New Member
    NYC
    2007 Toyota Tundra Crewmax 5.7 Limited
    Horn baffle delete Fox 2.5 DSC Setup DAP TUNED RW WHEELS 285/75/17 AT3 LTX
    Super clean. Cheap and effective
  6. Nov 25, 2019 at 11:25 AM
    Grumpy Uncle
    Pat
    CO
    A Simple Green soak and scrub then my pressure washer. Works for me.
  7. Nov 25, 2019 at 11:29 AM
    War Machine
    War Machine SSEM # 5 3MW
    This is the best I’ve tried, and only one I recommend.
  8. Nov 25, 2019 at 11:34 AM
    Stocky Balboa
    OC , CA
    Crap. Just found the previous thread on this.
    My bad. Thanks for the feedback.
  9. Nov 25, 2019 at 12:19 PM
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Leer 100XL, Bedrug, Go Rhino running boards, LED int/ext lighting, Bilstein 6112/5100 1/2”shims up front, Coachbuilder +3 shackles, CB drop, TRD front/rear sway bar, 275/65/20 Michelin LTX M/S 2, sequoia painted mirror cap/door handles, Rago Fab low pro ditch brackets, Baja Designs S2 sports ditch lights. Baja Designs S2 sport rear flush mount pod
    For the tires I use chemical guys nonsense invisible all purpose cleaner. Not only does it work well for the tires but you can use it on wheel wells and interior, just be sure to dilute a touch. I like it because I used to use Wesley’s bleach white but it always dried everything out after time. I scrub my tires with a medium firmness brush and the nonsense cleaner and let the tires air dry, after that I can shine them or leave them bare. I had some nasty looking tires after a vacation but you can see they came out perfect 9BD203B0-7555-45E3-B919-FCEDEDD4770C.jpg48006823-EB2B-408D-9F61-1B452A3D103C.jpg
    TheBeast and Stocky Balboa[OP] like this.
  10. Nov 25, 2019 at 12:23 PM
    ARMYGREEN
    ARMYGREEN New Member
    2014 CrewMax MGM
  11. Nov 25, 2019 at 1:00 PM
    Stocky Balboa
    OC , CA
    & the blood & the beer?
  12. Nov 25, 2019 at 1:02 PM
    Stocky Balboa
    OC , CA
    Looks good. Heres what I’m dealing with.
    Tundraman1000 likes this.
  13. Nov 25, 2019 at 1:17 PM
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Get you some of that cleaner. I bought a gallon and have been mixing it w water. Although when they are that dirty you’ll need full strength.
  14. Nov 25, 2019 at 1:19 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    Purple power.
  15. Nov 25, 2019 at 1:20 PM
    Civiceg94
    NYC
    Superclean is really cheap and really good on anything. Dilute it to whatever your using it on on tires full strength. Its like 6 bucks for a gallon. Cant beat that and if you didnt like the results it was only 6 bucks compared to other brands being 20 bucks and beyond. And you still could use it for a range of things.
  16. Nov 25, 2019 at 1:29 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Adams tire and rubber cleaner is great
    Burdturger likes this.
  17. Nov 25, 2019 at 1:37 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Leave it. The brown looks good.
    Civiceg94 likes this.
  18. Nov 25, 2019 at 1:53 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Acid rain, especially when it forms deep clear puddles.
    Hbjeff likes this.
