What the hell is this?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Abos, Sep 10, 2022.
  1. Sep 10, 2022 at 5:50 PM
    Abos
    Abos [OP] Long live 5.7L V8
    2014 SR5 Crewmax
    I was chasing down a heat shield rattle and I noticed this broken wire housing. There is no wire in it and it just kind of flakes away. I can't figure out what it would be for. I'm sure someone here knows. No CEL or issues. Just happened to notice it. 20220910_182223.jpg
    NewImprovedRon likes this.
  2. Sep 10, 2022 at 5:52 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Its the grounding wire for the transmission, pretty easy to replace.
  3. Sep 10, 2022 at 5:54 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  4. Sep 11, 2022 at 3:42 AM
    Abos
    2014 SR5 Crewmax
    Good deal, thanks guys. I figured it was some sort of ground wire but I wasn't sure what the point was as I'm not suffering any adverse effects. I did order the new strap above so I'll throw it back on since it's an easy quick fix.
    Bob and IsaiahCanada like this.
  5. Sep 11, 2022 at 4:01 AM
    Retired...finally
    A note on how important ground straps can be. The original Dodge Omni and Plymouth Horizon models had a problem with premature front wheel bearing failures. The cause was found to be a ground strap that was bolted to the engine but had a toothed push on connection at the painted unibody. The connection wasn't electrically sound so some current passed through the engine, drivetrain and wheel bearing to the front suspension and to chassis ground. The arcing in the bearings caused them to fail. I worked for a Chrysler Dodge Plymouth dealer when the service bulletin came out. Fix was to scrape the paint away on the unibody under the ground clip.
  6. Sep 11, 2022 at 7:06 AM
    Joe333x
    Joe333x Member
    Boston
    A Facebook group member said he was having issues with bad shifts which is what prompted him to replace his and it fixed his issue.
  7. Sep 11, 2022 at 8:35 AM
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    Fix that asap.It will cause issues
    Rdrcr and rodl12 like this.
  8. Sep 11, 2022 at 10:44 AM
    Abos
    2014 SR5 Crewmax
    I will be for sure. I already ordered the part. I have no idea how long it's been broken. Probably quite a while.
  9. Sep 11, 2022 at 11:07 AM
    TheBeast The Beach
    good info. thx guys
    majbjb and Abos[OP] like this.
  10. Sep 11, 2022 at 11:53 AM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    I welded 3 transmission shift cables before I realized the ground wire wasn't reinstalled after removing the engine. Not on a Tundra but none the less they are important!!
  11. Sep 11, 2022 at 12:38 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Im going to check mine for curiosity, thanks for the info
    IsaiahCanada and Abos[OP] like this.
  12. Sep 12, 2022 at 6:05 AM
    Abos
    2014 SR5 Crewmax
    I ended up buying one at the local part store and put it on yesterday. Took 5 minutes and luckily I was able to get the nuts off without snapping anything. Crazy, the thing had basically disintegrated.
    Should be good for another several years now.
    HulkSmurf14 likes this.
  13. Dec 1, 2023 at 7:23 AM
    rodl12
    rodl12 New Member
    Rod
    South Jersey
    2017 Tundra SR5 Double Cab
    I will. I'm wondering how long it was broken.
  14. Dec 1, 2023 at 8:46 AM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Strange thing I remember that when I first started my automotive career.
  15. Dec 2, 2023 at 4:16 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    Thanks for this I'll have to check mine....
  16. Dec 12, 2023 at 5:02 PM
    c24680
    c24680 New Member
    Craig
    KY
    08 Silver Tundra Crew
    This
    Checking mine too
    Ordered the above one as insurance for my 08cm
  17. Dec 14, 2023 at 8:19 PM
    c24680
    c24680 New Member
    Craig
    KY
    Good thing I ordered one Tuesday.
    Checked under my truck and found this, not best picture
    Hoping it fixes some issues but my luck prolly not. Hope to mess with it tomorrow or Saturday
    Thanks again all
    HulkSmurf14, Joe333x and Jaypown like this.
  18. Feb 19, 2024 at 1:22 PM
    1Tundra5
    1Tundra5 New Member
    Junior
    2015 White SR5
    Is there a ground bolt for headlights?
  19. Feb 20, 2024 at 9:33 AM
    Kung
    KG, VA
    Heh.
  20. Jul 21, 2024 at 7:01 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    I have the same issue with that ground wire rusted on my Sequoia for a long time. However, I never really noticed any issues with transmission or transfer case going into/out of 4WD. I replaced it with the 15" ground wire from Dorman on Amazon just in case. 15" is way too long but it'll do.
  21. Jul 30, 2024 at 2:02 AM
    USERidiculousNAME
    USERidiculousNAME ToyTurd
    Josh
    New Orleans
    250K on Early 2004 tundra DC 4.7 v8, SR5, RWD, A/T, LSD, w/ABS,TOW, OFF ROAD, ZERO RUST FRAME, BILSTIEN 5100, AAL, 17" 265/70
    Backup camera, camper shell, double din stereo, amp, sub, blind spot cameras, modest lift, newer Tacoma rims, large AT tires, interior lighting upgrades, in bed, under hood, as well as leds in cab, blue foot well strips (night driving)or bright white strips if need to see, 3 additional white leds on ceiling front L/ R and center, toggle switch's and added accessory fuse box.
    I want to go check mine now since my truck is 10-15 years older then everyone that is posting 04 by the way
  22. Jul 30, 2024 at 7:22 AM
    R Mannino
    R Mannino New Member
    Ron
    2016 TRD
    Air bags
    Thanks for the tip! Just rolled under mine and it's toast, hopefully this fixes the funky downshift I've noticed lately.
  23. Jan 22, 2025 at 11:54 AM
    AlexOd
    AlexOd New Member
    Mine has too .. why is happing ?
    Somebody did on purpose?
  24. Jan 22, 2025 at 7:08 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Rust. That strap is exposed to the element. Water, salt, sand, mud.. etc.. it will eventually corrode off. Easy and simple to replace.
  25. Jan 24, 2025 at 7:06 AM
    Yoymon
    Yoymon New Member
    2015 tundra
    Found same thing on mine checking the heat shield rattles, used a thick Guage wire that I had to replace it for now
  26. Jan 24, 2025 at 7:40 AM
    BrandonL812
    Brandon
    Made my own. Completely shielded from the environment.
    This is what it look like at 46k.
    omgboost, HulkSmurf14 and 1lowlife like this.
  27. Jan 24, 2025 at 7:52 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    :yes::spending:
  28. Jan 24, 2025 at 8:05 AM
    BrandonL812
    Brandon
    Part list if you want to make your own:
    1. Temco 4/0 welding cable
    https://www.ebay.com/itm/2822085349...2fXpNIpQmm&var=&widget_ver=artemis&media=COPY
    2. Ring terminals
    10pcs 4 Awg - 5/16" (M8) TKDMR... https://www.amazon.com/dp/B08R6Z38C4?ref=ppx_pop_mob_ap_share
    3. Rosin core solder. Get the thick kind. Thicker better.
    4. Utility torch
    https://www.walmart.com/ip/17128613?sid=e1ad3291-b48c-4022-844c-9e0158d479f8
    Use a locking vise grip or a table vise. Lock the ring terminal in. Heat up the ring terminal. Melt in the solder core up about half way the ring terminal. Insert stripped welding cable in to hot ring terminal. Let cool.. add heatshrink with adhesive inside. Heatshrink tube from #2 above works just fine. Cut it in half.
    Done.
    Shanet421 likes this.
  29. Jan 24, 2025 at 8:14 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    ^^This..
    If one is too lazy to solder, I've had good results with this crimper..
    I never did mount it, it sits in a drawer..
    TEMCo Hammer Lug Crimper Tool - Crimps 8 AWG to 4/0 Battery & Welding Cables (Workbench-Mountable) - Battery Terminal Crimper - Amazon.com
  30. Jan 24, 2025 at 7:14 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Actually that is the proper way. You shouldn't solder large diameter wire. Crimp and use heat shrink. Heating the wire and soldering will cause the wire to fail as it wiggles and moves.
    HulkSmurf14 and kirkb like this.
