What the hell is this noise??
Discussion in '1st Gen Tundras (2000-2006)' started by Randal Scott, Oct 16, 2024.
  1. Oct 16, 2024 at 10:29 AM
    Randal Scott
    Randal Scott [OP] New Member
    2004 Tundra SR5 Crew cab
    Hey Folks, first post. 2004 tundra Crew cab, 475k miles.
    I recently had my front brakes replaced, pads, shoes, discs, everything. Also had front passenger and rear drivers side wheel bearings replaced.
    Shortly after I would hear this noise when turning and stopping to park. If I go super slow you don't hear it. If I stop straight you don't hear it. But turning and stopping you can hear it 75% of the time. Brakes fine, drives fine. Nothing noticeable otherwise.
    I recorded these 2 clips with my phone:
    https://streamable.com/i7g17n
    What the hell is that noise??
    Weagle likes this.
  2. Oct 16, 2024 at 12:01 PM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    Sounds like your ABS system activating. Likely one of the ABS tone rings wasn't pressed back in to the proper location during the wheel bearing replacement or one of the ABS sensors is dirty or damaged. Assuming a shop did the work, I'd take it back and have them verify those components. If you want to check it yourself, the process is not too difficult.
    Fobroader likes this.
  3. Oct 16, 2024 at 1:31 PM
    Randal Scott
    Excellent insight, Thank You! Given it started right after the wheel bearing replacement, I'm guessing the former is the problem.
    Dustbox likes this.
  4. Oct 17, 2024 at 2:06 PM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    I had that problem. It only happens below 5 miles an hour, but mine would also do it straight ahead. If it's ABS most likely you can feel it in the brake pedal
    my issue was like others I've read in this forum - started immediately after some front end work And they swear they didn't touch them. The O-rings for those sensors are old and stretched out, so it's easy to knock them out of alignment or if they take them out and put them back in to pinch the O-ring, which keeps it from being centered
  5. Oct 17, 2024 at 2:36 PM
    Randal Scott
    Interesting, but not in my case. Aside from the sound, nothing else seems different at all.
    But this additional info is great--now I know exactly has to address the problem. Thanks!
  6. Oct 18, 2024 at 12:54 AM
    shifty` I'm having daydreams about night things
    This conversation comes up a lot, and @Weagle has graciously helped several people with it. You may want to read this, from one of the more recent cases: https://www.tundras.com/threads/much-needed-help.148618/#post-3718511
