What spark plugs?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Erick, Feb 2, 2023.
  1. Feb 2, 2023 at 3:47 PM
    Erick
    Erick [OP] New Member
    Erick
    Thornton Colorado.
    Bronze 2016 SR5 TRD. CM cab.
    HID lights, Duratracs, Bilstein 5100's, 2" Spacer, Sumo springs.
    I’m nearing 120k. I don’t know what spark plugs I need. I found a thread a week ago with an eBay listing of oem spark plugs. I can’t seem to find it anymore.
    Also, does anyone know what kind of anti seize and what kind of grease I need to put on my spark plugs?
  2. Feb 2, 2023 at 4:27 PM
    CTundraForMe
    CTundraForMe New Member
    Watching. In the same boat here.
    I've heard from family members that it's best to pay someone to do it; 7 years is a long time. If something goes wrong getting the old plugs out, it's on them.
    Curious what others have to say.
  3. Feb 2, 2023 at 4:50 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  4. Feb 2, 2023 at 5:01 PM
    AZBoatHauler
    So.Arizona
    I’d only get them from a dealer as I’ve seen what the counterfeit ones do inside the cylinder.
    A dab of dielectric grease in the boot and some spray silicon for the boots if you’re fancy and you should be gtg.
  5. Feb 2, 2023 at 6:19 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Also not recommend to use anti seize on your spark plugs. It’s not 1979 anymore
  6. Feb 2, 2023 at 7:14 PM
    centex
    centex New Member
    I use antiseize on every plug in every vehicle and I’ve never had issue one. I’ve also never had to fight pulling spark plugs afterwards either. Use the copper one and just a light coating on the threads.
    JLS in WA and texasrho83 like this.
  7. Feb 2, 2023 at 7:23 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    I’d buy OEM from a dealer. Second the dielectric grease on the boots. I used a very light dab of copper anti seize on mine and then torque.
    It’s not hard.
  8. Feb 2, 2023 at 7:30 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Agreed. Common sense dictates not slathering it on in gobs and not letting any of it get into the combustion chamber.
  9. Feb 2, 2023 at 7:30 PM
    CTundraForMe
    My concern is getting them out, not in!
  10. Feb 2, 2023 at 7:34 PM
    AZBoatHauler
    So.Arizona
    It’s not a Ford. :blahblah:
    hagrid, JLS in WA and FrenchToasty like this.
  11. Feb 2, 2023 at 7:41 PM
    FrenchToasty
    Mo
    Bone stock
    Common sense is hard to come by these days
  12. Feb 2, 2023 at 7:44 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'm a public school teacher so I know all too well
  13. Feb 2, 2023 at 7:45 PM
    FrenchToasty
    Mo
    Bone stock
    I work at a place of higher education, lord help us all
  14. Feb 2, 2023 at 7:47 PM
    Erick
    Erick
    Thornton Colorado.
    Does anyone have a link or can at least tell me where I can get oem plugs ordered?
  15. Feb 2, 2023 at 7:50 PM
    FrenchToasty
    Mo
    Bone stock
  16. Feb 2, 2023 at 7:52 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
  17. Feb 2, 2023 at 7:54 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  18. Feb 2, 2023 at 7:58 PM
    AZBoatHauler
    So.Arizona
  19. Feb 2, 2023 at 8:18 PM
    JLS in WA
    Mine were in for 14 years and 90k miles and came out easy. Use a shot of penetrating oil if they’re sticky.
  20. Feb 2, 2023 at 8:20 PM
    JLS in WA
    https://parts.toyota.com/
  21. Feb 3, 2023 at 10:19 AM
    gizardlizard
    gizardlizard New Member
    Madison,WI
    2017 TRD pro Tundra
    6” lift, 35 inch tires, chrome delete, ridiculous stereo
    I always use anti seize on old steel heads for spark plugs but NEVER on aluminum. Bad idea.
  22. Feb 4, 2023 at 4:55 AM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    Yup, if you have a dry torque value and add lube it really increases the strain of the fastener. Much like lug nut torque and how adding oil can result in stretching the stud so far it snaps.
    Some plug brands even say on the box the chrome plating is all the lube it needs. I presume it's by acting as a barrier between the aluminium head and steel plug to prevent corrosion.
  23. Mar 6, 2023 at 10:31 AM
    CTundraForMe
    Does anyone have the Toyota P/N handy for these? I found 90919-01191 but the description is a bit ambiguous as to whether it's Iridium (120k miles) or Platinum (60k miles).
    Seems getting Denso 3421 from Rockauto may be the best option?
  24. Mar 6, 2023 at 10:37 AM
    AZBoatHauler
    So.Arizona
  25. Mar 6, 2023 at 11:15 AM
    CTundraForMe
    Thanks for the pic. Said a whole lot more than the item description on the toyota parts site said!
    Should I replace the plug wires as well? I don't see anything in the maintenance schedule about replacing plug wires.
  26. Mar 6, 2023 at 11:18 AM
    AZBoatHauler
    So.Arizona
    These engines have individual coil packs so they don’t have traditional spark plug wires.
  27. Mar 6, 2023 at 11:19 AM
    CTundraForMe
    That means they are expected to last forever and not replaced short of rodent damage?
  28. Mar 6, 2023 at 11:23 AM
    AZBoatHauler
    So.Arizona
    Correct. If you need to replace anything down the road - it would probably be a coil pack but it’s rare they go bad. If you have a misfire that follows the coil pack if you move it cylinder to cylinder it would need replaced. Not considered normal maintenance IMO.
    CTundraForMe[QUOTED] likes this.
  29. Mar 6, 2023 at 11:40 PM
    kevine0001
    kevine0001 New Member
    Kevin
    Denso iridium. Napa sells them. I’ve heard the NGK iridium works also if you can’t get a hold of Denso
    for the ignition coil, I had to replace one on my 2000 Land Cruiser…at 225k miles. On trail too. And of course, it was #7, against the fire wall. Not super hard but having an OBD code reader helped diagnose. 1-6 are fairly easy. The two against the firewall can be a PITA. But unless you’re misfiring or it feels sluggish, don’t mess with the coils
    Giskk and WFD473 like this.
  30. Mar 7, 2023 at 3:24 PM
    Ebrperk
    Ebrperk Old member
    South Central Kansas
    2018 1794 MGM
    Tinted windows, go rhino D6 side steps and shorty antenna, Bilstein 5100's rears, 6112's fonts set to 2.5" Rocktrix RT111 18x9 -12offset NItto Terra Grapplers G3's 275/70 R18's. Amp from James @ Tech12volts FRAC Harness
    kevine0001 and WFD473 like this.
