What size wheels n tires?
Discussion in 'Wheels & Tires' started by xk1, Apr 18, 2018.
  1. Apr 18, 2018 at 10:13 PM
    xk1
    xk1 [OP] Yota Mob Prospect
    14 Magnetic Grey TSS
    Hi, Was wondering if anyone (in the same or similar boat) could help me here with getting the right wheels/tires. Firstly, I have read all the awesome info in relation to this topic, but I'm still at a loss....I have the toytec 3/1.5" boss lift and 2" spacers, I've been researching upgrading the wheels for a while and doing away with these spacers. So I'm after the slightly aggressive look - I do have fender flares so even 2" spacers are minimal specially in the front, so question is what wheel do I go - what backspacing to at least maintain what those 2" spacer give with stock 20" rims. I don't really want to cut more than tht silly flap I alrdy took off which rubbed in tight turn reverse w/ stock before the lift anyway, I've got alot more clearance now plus toytec also put spc UCA's in as well...I'm about f'd in my garage for overall height with the stock 20's and 3" lift (had to mod. garage door arm/7' header) ....should I go 18 with bigger /wider tire?.or20..i'm prepared to build a garage to park her tho....god tht sounds fecked ! but we do what we love.....
  2. Apr 19, 2018 at 4:43 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Welcome from Obx XK1,
    Here's a + 10 offset with 33 12.50 20's. It has no flares, but depending on what flares you have , would give you that slight aggressive look. If you want more stick out, go down on your offset. As far as size, me personally would go down to a 18" set-up vs 20, just my .02. I have 11/4" spacers on my factory +60 and 295/70/18, no flares. Stick out is exactly what I was looking for. 1st pic is the +10 offset, it's a pic of one of our members, just wanted to give you an example. 2nd pic is mine. Hope this helps:thumbsup:
    xk1[OP] likes this.
  3. Apr 19, 2018 at 8:12 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    What size tires are you currently running @xk1 ?
  4. Apr 19, 2018 at 9:15 PM
    xk1
    I have 285 / 55 R 20 atm. Zc.
