What size tire can I put on this wheel?
Discussion in 'Wheels & Tires' started by Scott15, Dec 19, 2016.
  1. Dec 19, 2016 at 7:20 PM
    Scott15
    Scott15 [OP] New Member
    Hello,
    I'm running this wheel that came with my 15 DC 4x4 XP. I currently have 275/60/20 Nittos on it with a 3/2 level lift. When I added that I had to bend up the ears on the skid plate a bit. Also add 1.5" spacers since then.
    The guide at the beginning of this thread, if I'm reading it correctly, says I can run 285/65/20 I assume that would require more bending.
    My question is how big of a tire can I put on the wheel and what are the cons in doing so?
  2. Dec 20, 2016 at 10:08 AM
    Scott15
    Is the question that stupid??? lol... Anyone?
    Law323 likes this.
  3. Dec 20, 2016 at 10:22 AM
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    What size is the wheel? 20x9? 20x10? Offset/backspacing?
    Are you looking for the best tire you can get on there, or the biggest one that will fit on that wheel AND under your truck?
    Backslider, Bob and NewImprovedRon like this.
  4. Dec 20, 2016 at 10:43 AM
    Scott15
    That's the problem Ron. I have no idea. I'd like to go a little wider and maybe taller. I've been to 2 diff tires stores in the last few months and asked them and get blank stares then the comment along the lines to put the same size that already on there.
  5. Dec 20, 2016 at 10:47 AM
    sdhq_offroad
    GILBERT, AZ
    If you are able to take the wheel off the truck, it will give you those dimensions on the inside casted into the spoke. Then you would just have to measure the backspacing. Google how to measure it.
  6. Dec 20, 2016 at 2:02 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    If you run 285/65/20 that's about 34.6". With your wheel spacer, you'll probably clear your UCA's and bending the skid plate is no big deal, but that depends on your offset. The issue is most likely going to be your body mount along with your mudflaps and front liner.
    Law323 and Scott15[OP] like this.
  7. Dec 31, 2016 at 7:45 AM
    Scott15
    Are these the stamps on the wheel I'm looking for?
  8. Dec 31, 2016 at 8:17 AM
    Scott15
    Better picture - So the offset is positive 5?
  9. Dec 31, 2016 at 8:37 AM
    sdhq_offroad
    GILBERT, AZ
    ET 50 would be a positive 50mm offset from my understanding
  10. Dec 31, 2016 at 8:43 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yup +50
  11. Dec 31, 2016 at 8:44 AM
    Scott15
    I should be ok with the 285/60 R20. Do you think the 305/60 R20 would fit without trimming?
  12. Dec 31, 2016 at 8:44 AM
    sdhq_offroad
    GILBERT, AZ
    From what I can find on the interwebs. The Tundra bolt pattern was made in a 20x9, +35 offset.
  13. Dec 31, 2016 at 10:12 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    With your +50 and 1.5" spacers, that puts you at about a +12 offset. 305/60/20 is about a 34.4" tire. You will more than likely rub your mud flaps and the front liner. And will be very close to your cab mount.
  14. Dec 31, 2016 at 10:40 AM
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    Based on my limited experience, I'm running a 3/1 level on 20x9 +25 combined with 295/60 and I had to remove all the front wheel flaps, heat mold my liner at the front and I barely clear the cab mount. With his spacers creating a +12 offset I'd say he would hit the cab mount with 305/60's. He might be able to squeeze in 285/60's.
    Scott15[OP] likes this.
  15. Jan 2, 2017 at 11:34 AM
    Scott15
    I went with the BFG K02 and the same size I had 275/60 R20. It would not of taken a bigger tire without some work in the front of the wheel well. I'm getting a very slight rub with the wheel completely turned in reverse. Thanks again for all the input.
    FYI pics -
