what shocks would be best for light towing
Discussion in 'Suspension' started by atl1glf, Mar 15, 2019.
  1. Mar 15, 2019 at 5:35 AM
    atl1glf
    atl1glf [OP] New Member
    ‘07 SR5 CM, ‘12 SR5 DC Supercharged, ‘19 Limited CM
    Too many TRD parts
    I have an ‘07 2wd CM 5.7 that I use for mobile detailing. I tow a trailer that at the most would be 2800lbs. I have stock 20” wheels with 275/55 tires and stock black suspension.
    I plan to add the trd sway bar for the rear.
    I believe my shocks are worn out because im experiencing way too much bounce on the interstate.
    Would the 5100’s all the way around be the best option for a better ride over stock and last longer or is there something else that you would recommend?
  2. Mar 15, 2019 at 5:47 AM
    Bilstein 4600
    Watt maker likes this.
  3. Mar 15, 2019 at 7:12 AM
    atl1glf
    Too many TRD parts
    Thank you
