What shocks should I get?
Discussion in '1st Gen Tundras (2000-2006)' started by rcalbuquerque, Mar 14, 2019.
  1. Mar 14, 2019 at 1:42 PM
    rcalbuquerque
    rcalbuquerque [OP] New Member
    Lou
    2002 tundra
    Stock
    Hello
    I have a 02 tundra xtra cab 2wd with 125000 miles
    Truck is in nice shape only drivin on highway.
    I occasionally tow a cargo trailer at about 3000lb
    Thinking about new shocks and struts...
    What brand is recommended here for a great ride?
  2. Mar 14, 2019 at 2:33 PM
    Professional Hand Model
    Hand Protectors
    Welcome. Based on your set up and occasional towing you should consider the Bilstien 5100 set up. I’ve had them on my truck for about 9 months and love them for city/tow/haul. Off-road they may be stiff. Road driving they are sporty.
    There are other options out there for way more $$$ and the decision making process may be confusing.
    Check out the ‘What have you done’ section for some ideas.
    Filthyphil and Black Wolf like this.
  3. Mar 14, 2019 at 3:00 PM
    Cacoleman2014
    Cacoleman2014 New Member
    Louisiana
    2006 Tundra SR5 double cab
    That's really nice for an 02! Definitely look at the 5100's.. You can find deals if you shop around.
  4. Mar 14, 2019 at 3:06 PM
    rcalbuquerque
    Lou
    2002 tundra
    Stock
    If I were to go with the 5100’s what ride height should I choose?
    Thanks for the replies
  5. Mar 14, 2019 at 3:08 PM
    rcalbuquerque
    Lou
    2002 tundra
    Stock
    The truck drives nice now but I’m thinking it must be time and perhaps I could improve the ride quality
  6. Mar 14, 2019 at 3:08 PM
    Cacoleman2014
    Louisiana
    I believe level on that truck is the 3rd.
  7. Mar 14, 2019 at 3:26 PM
    rcalbuquerque
    Lou
    2002 tundra
    Stock
    I have had the truck for about 6 years trouble free....
    I have it set up to pull behind my RV with a driveshaft disconnect B346B1CE-2624-4C6F-9A39-17DA90A85449.jpg
  8. Mar 14, 2019 at 3:42 PM
    Hand Protectors
    Stock or plus one up from stock.
  9. Mar 15, 2019 at 6:54 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    5100’s are nice and they will level the truck. But if you tow occasionally, you’ll be nose high. Personally I would leave around 1 inch of rake in the rear. Rear 5100’s are not adjustable if you didn’t know.
  10. Mar 15, 2019 at 7:25 PM
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    Fox or sway a way coilovers would be good or ranch’s quick lift if they make it for our trucks
