What setting for Bilstein 5100's?
Discussion in 'Suspension' started by Popcan, May 7, 2022.
  1. May 7, 2022 at 10:11 AM
    Popcan
    Popcan [OP] New Member
    Warren
    2018 Blue Sr5 off road dbl cab TRD
    Hi all,
    Just pulling the trigger on a Warn semi-hidden bumper (with tube) and a SB 12k winch to put on my 2018 SR5 Tundra.
    At the same time, I'm getting the 5100 Bilsteins' installed on the front.
    To level the truck, taking into account the weight of the bumper and winch, what setting do you think I'll need... middle or top?
    Thanks!
    edited to add: winch = 78lbs, bumper = 83lbs
  2. May 7, 2022 at 1:13 PM
    Blueknights75
    Ron
    Clayton, NC
    Top setting…. I am running top setting on stock platform and I am perfectly leveled with no rake whatsoever.
    MER and Popcan[OP] like this.
  3. May 11, 2022 at 2:54 PM
    MER
    MER New Member
    18' Limited CM 4x4 Off Road
    Did you have to get new top hats when you installed the 5100’s? Thx
  4. May 11, 2022 at 3:15 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    I'd just reuse your OE top hats. They're much better than KYB if you were to get aftermarket.
    MER[QUOTED] likes this.
  5. May 11, 2022 at 3:16 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Using the top would probably be the best option.
  6. May 11, 2022 at 3:35 PM
    Popcan
    Warren
    I’m planning to reuse the tops, but it’s not done yet as I am waiting for the Warn bumper to arrive, and get it all done at once.
  7. May 11, 2022 at 3:47 PM
    Half track
    Half track New Member
    Rob
    Western Nevada
    2020 Silver Tundra SR5 TRD, 38 gal tank
    Tow Mirrors
    I set them at the middle setting. Just a small rake. Easy to see in front.
  8. May 11, 2022 at 4:30 PM
    Blueknights75
    Ron
    Clayton, NC
    No sir.
