What service to perform at 37k?
Discussion in '2.5 Gen Tundras (2014-2021)' started by gdiep, May 3, 2018.
  1. May 3, 2018 at 3:59 PM
    gdiep
    gdiep [OP] I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    I have a 2014 with 37k miles. It needs an oil change. I should do it myself, but am also thinking about doing the diffs. However, I’ve been so busy with work and the kids sports, that I’ll likely get the dealer to do the work. We tow a travel trailer so i’m Erring on the safe side. Question is what work to have them do?
    Front and rear diffs?
    Transfer case?
    Anything else?
  2. May 3, 2018 at 4:07 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    I do my engine oil every 5k, diffs around 30k. I did my transfer case at 47k along with the diffs again and the transfer case oil was pretty dirty. I guess it depends on how you use your truck.
  3. May 3, 2018 at 5:04 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    I would have them perform whatever is due at 40K miles.
  4. May 3, 2018 at 7:02 PM
    tacomawv
    tacomawv New Member
    Richard
    The rear diff. I just did mine. It does a lot of work. My oil is due and i am going to change it and the front diff at the same time. I have a 2014 with 37000 too. They say the transmission too. Mine had a leak that was fixed. They replaced a good bit of oil then. I am going to let it ride till next time. I am saving up for the transfer case oil. It is $$$$$.
  5. May 3, 2018 at 7:22 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    the transmission fluid is rated at 100k for "severe duty", lifetime for "normal duty" - on my last Tundra I had it done at 50k, at around 110k when I bought my new Tundra, there wasn't a noticeable difference in the actual gear changes (the transmission software seems to have gotten much better from 2nd to 3rd gen though) - that leads me to believe the 100k interval for "regular driving" may be good
  6. May 3, 2018 at 7:43 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Diffs, transfer case and Brake fuid believe it or not, Toyota recommends flush at 30k
  7. May 4, 2018 at 3:16 AM
    gdiep
    Syracuse, New York
    Thanks all.
  8. May 4, 2018 at 3:27 AM
    l3LUEFALCON
    l3LUEFALCON RIG MECHANIC
    Josh
    North Houston Area
    2014 5.7 FFV MGM CM SR5 4WD TSS-OR AKA: MILDRED
    (DIY) CB Radio, Tool Box, ESP Under seat storage, Husky front/ Weather tech rear floor mats, (DIY) Console Safe (Bio-metric), 275/60/R20 Conti Terrain Contact, Magnaflow Exhaust, Katskin leather seat covers, LRA 46 gallon replacement fuel tank, TRD Pro shocks Front/Rear.
    I use full synthetic German Ravenol.
    http://www.ravenol.de/en/oil-guide.html
    *HINT: On the oil guide you must select "car" to get you to select the Tundra model.
    This will tell you all your fluid change scheme.
  9. May 4, 2018 at 3:31 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I changed transfer case at 50k on my Tacoma and it looked brand new. I see no sense in changing transfer gas at 37k unless you use 4wd a whole lot.
  10. May 4, 2018 at 4:27 AM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    I agree with this, my Tacoma was the same way. But the Tundra could be different I guess, now rear differential is a different story. The rear diff fluid looks pretty dirty at 30k from my experience.
