What rotor & pads brands do you like for your Tundra?
Discussion in '2nd Gen Tundras (2007-2013)' started by Benlee, Mar 20, 2025.
  1. Mar 20, 2025 at 9:25 AM
    Benlee
    Benlee [OP] New Member
    Ben
    2008 Toyota Sequoia (Limited)
    I need to do a brake job and I would like to replace all 4 rotors since I'm getting pulsing when I brake, and I can feel groves worn into the rotors, and I was thinking about using Akebono for the rotors and pads (ceramic) since they seem to have a really great reputation for quality, but they are quite expensive and harder to find, especially locally.
    I wanted to see what brands you guys like to use, and I'm definitely not trying to find the cheapest option out there, but maybe a middle-of-the-road option that is still good quality.
    Thanks!
  2. Mar 20, 2025 at 11:04 AM
    socaldiablo
    socaldiablo New Member
    Carlsbad, CA
    2013 White Tundra SR5 Rock Warrior
    Leer camper shell, slight lift kit, TRD Pro BBS wheels
    I'm using Bosch rotors, Akebono front pads, and Bosch rear pads. All has been great since I replaced the OEM set-up, which had warped rotors after only 24K miles (previous owner towed a boat).
  3. Mar 20, 2025 at 11:19 AM
    Benlee
    Ben
    Great, thanks for your input. Just curious, why Akebono pads on the front and Bosch on the rear?
  4. Mar 20, 2025 at 11:50 AM
    socaldiablo
    Carlsbad, CA
    Good question ...I ordered the Bosch F/R pads and rotors but then ended up needed some more maintenance done on my truck so took it to my mechanic for that work and just had him do the brake job and he informed me the front pads I gave him didn't fit right so he sourced Akebono pads instead. The front pads I sourced were supposed to fit ...not sure what happened at the retailer but I went back and double checked the part number was correct for my model year. At my next brake job, I'll probably spring for all Akebono parts. But my current set-up works well, too.
  5. Mar 20, 2025 at 12:13 PM
    Benlee
    Ben
    Gotcha. Now that you mentioned the Bosch brand, I decided to check on Rock Auto to see if they had them, and they seem to be quite a bit cheaper than Bosch rotors on Amazon. Rock Auto does not have Akebono, and I'm not sure that I like any of the brands that the local auto parts stores have (AutoZone, Oriley Auto parts), so I may go with Bosch pads and rotors from Rock Auto for the front and back, and hope that it all fits right.
  6. Mar 20, 2025 at 12:31 PM
    ChesterTundra
    ChesterTundra New Member
    Central FL
    2020 Tundra SR5
    RCI Alum skids w/cat guards Leveled and AT Cooled SPD Performance exhaust Amsoil everywhere…
    Advics is another brand Toyota uses, and RockAuto does sell them. Advics is my go to brand for Toyotas having warping issues (pads and rotors). My Sienna's calipers are stamped Advics right on them.
    WILLINH likes this.
  7. Mar 20, 2025 at 12:39 PM
    Thumper_6119
    Thumper_6119 I've seen things you people wouldn't believe.
    2011 Toyota Tundra SR5 Texas Edition (Crewmax) 4x4
    I just purchased StopTech slotted cryo rotors, front and back, and Akebono ceramic pads, front and back. I will, hopefully, be installing those this weekend.
  8. Mar 20, 2025 at 2:31 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I splurged a fee years back with Stoptech slotted and cryotreated on EBC yellow.. currentlu running 3 since 1 rear brake rotor seized and tore it up.
  9. Mar 20, 2025 at 3:08 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Frozen cryo rotors and stock pads is great all around performance.
    Matala likes this.
  10. Mar 20, 2025 at 3:16 PM
    bflooks
    bflooks New Member
    Metrowest MA
    I'm rocking the Stoptech Cryo blanks (not Sport) and Hawk LTS pads. The combo is ridiculously predictable, including while towing heavy, but OMG do the pads throw an unimaginable amount of dust. It's rather obnoxious.
    Matala likes this.
  11. Mar 20, 2025 at 5:51 PM
    FFR1910
    FFR1910 New Member
    I have used powerstop rotor and pad kits on my sequoias for years. Will use on my tundra when the time comes. I use the kits with the drilled and slotted rotors.
  12. Mar 21, 2025 at 2:39 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    don't get slotted or drilled rotors if you plan on wheeling. i've always heard that mud and dust and rocks can build up in the grooves and wear down components faster. do what you will with that info. i stick to centric premium rotors and OEM pads. never done me wrong on any of my trucks.
  13. Mar 21, 2025 at 3:03 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Stoptech cryo rotors, akebono performance pads. No dust, better bite and no warp
    Thumper_6119 likes this.
  14. Mar 21, 2025 at 3:50 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Centric Premium Coated rotors with the Bosch QuietCast ceramic pads.
  15. Mar 21, 2025 at 3:53 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    IMHO…OEM
    Wallygator likes this.
  16. Mar 23, 2025 at 7:40 AM
    Rph74
    Rph74 New Member
    Springfield,MO
    2007 Tundra Crewmax Limited Silver/Redrock
    I did OEM from Toyota of Olathe it really wasn’t too bad of a price. For years I’ve been one to try to find ways to save money on aftermarket, lately with my Toyota’s, I’ve just gone OEM to take the guesswork out of it.
  17. Mar 23, 2025 at 10:47 AM
    Fedtime
    Fedtime New Member
    I’ve had good success with Brembo pads and rotors. They are sold here through Canadian Tire, of all places, and they put them on sale at 25% off from time to time, so I splurged once. I was impressed with the quality of the rotors and pads and they have held up well. I’ve run them on both my Tundra and our 4Runner. I’ve also had good success with Bosch and Raybestos.
  18. Mar 23, 2025 at 10:52 AM
    Wallygator
    Second this opinion, OEM all the way
    grave, CMikeB, Rph74 and 1 other person like this.
  19. Mar 23, 2025 at 9:35 PM
    tahoe
    tahoe New Member
    2013 RW, 6112 @1.9” front, 5100 rear
    I just put on frozen rotors (slotted) and Hawk green heavy duty pads. Love them. Follow the bedding in procedure for whatever you end up going with. Makes a big difference in avoiding future brake judder.
  20. Mar 24, 2025 at 1:48 AM
    CMikeB
    CMikeB New Member
    I have 88,500 miles on my OEM brakes. My Mechanic tells me I'll see 100,000 with no problem; so OEM.
    Wallygator[QUOTED] and Rph74 like this.
